Swamp cooler is not blowing cold air. Water is
My swamp cooler is connected to the water, but it is not blowing cold air. All other controls seem to be working fine.
    Sergeant:
  • 340 Answers
Is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
Nov 28, 2009 | Water Heaters
Swamp cooler is not blowing cool air
is the units Disturbing the water over the pads!
if not check the water pump!
are the pads old and worn out, buy new ones.
and if the Humidity is to high they do not work well
Jul 16, 2009 | Heating & Cooling
How do I unclog the copper line?
The copper line and the pump. Which is the concern?
On the circuit breaker, Turn it off and in five minutes, back on.. Then check the outlet at the cooler to see if it's getting power.The copper water supply line? You do have water to the float control valve? or no?
Jul 10, 2009 | Heating & Cooling
Evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
Jun 29, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Evaporative cooler pumps in dust
You should not have dust. Your water pump is probably shot. The hoghair might need to be replaced or the whloe unit might need a good hosing down. As far as a draft all the time? That is what you want in an evaporative cooler ain't it?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 16, 2009 | Mastercool 67471 Evaporative Cooler Air...
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Water Cooler Not cool
hi,
Please check the control.
May 06, 2009 | Heating & Cooling
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Shouldn't it be cooler?
Just found at least one problem with mine. I pulled off the back screen and then pulled off the back cover by undoing the two screws at the top. There is a pad in there that rotates through the water reservoir. If this pad doesn't get wet, you won't get any cooling. My pad was bone dry. Turns out the wire for the motor that rotates the pad was disconnected from the front control panel. I reconnected the wire and now the pad rotates through the water reservoir. We'll see how this works.
May 21, 2008 | NewAir AF-330 Air Cooler Fan
Heating & Cooling Logo
1,617 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
