Question about Ricoh Aficio 450 Copier
I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Posted on Jun 26, 2009
2 Suggested Answers
santosj27
  • 263 Answers
SOURCE: i have copier m/c ricoh
Hello!
This code refers to the fuser Unit. The temperature does not reach to the stand values.
It can be several problems like a open Thermostat or a broken lamp (among other thing, but let´s not going that way yet).
Try this to see if it works:
Press yellow key
Press 107 on the key pad
Press red key at least for 3 sec.
Press "copy SP" and exit all the way out.
Turn the machine OFF and turn ON.
Even if this work i advise you to call your provider because something on the fuser is wrong.
Hope this help´you.
See you
Posted on Apr 27, 2011
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Error sc 542
this is a fusing error
change the set of thermisters in the fusing unit
Jan 20, 2014 | Ricoh Aficio CL3500N Laser Printer
:Ricoh Aficio SP 3510SF error SC 542
Yes your MFP has had a fuser reload error. It's not permanent though. Sometimes the thermistors don't read the right temperature due to the thermistor getting excess toner built up on it or it gets moved away from the hot roller. This SC error usually can be reset by powering down the printer. It must be powered down correctly or you can corrupt the hard drive.
Hold the power button down on the operation panel until the screen goes dark. Then, physically turn the power switch off on the side of the unit. Once the unit has completely powered down and all lights are off, toggle the power switch back on. The unit should power back up normally. If the SC 542 returns, you'll have to have a technician check the fuser out.
Oct 24, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
Sc542
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Jan 22, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 450 Copier Logo
852 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
