Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
H400 WILL NOT LIGHT FAN WORKS
I TOOK THE ORFICES OUT AND ALL WHERE CLEAN IGNIGHTER ALSO WORK I TOOK IT OUT AND TURNED IT ON THE INNIGHTER GOT HOT AND STARTED STEAMING REGULATOR IS MOUNTED NEXT TO THE HEATER I HAVE PLENTY OF GAS 70%
  • 990 Answers
If your ignitor is getting white hot it is hot enough if it just get's red hot it may be low voltage. If this is not the problem than it has to be something keeping the gas from getting to the ignitor. If the ignitor is steaming then you may have a deeper problem with sweat on the exchanger wich may mean a venting problem. But the end result of this would be rusted or burnt burners and you will need to pull them and check to make sure they are letting gas flow correctly. Good luck.
Posted on Dec 10, 2009
My oven won't light.
Does it glow real bright like orange or just red. Because if it's not real bright orange, the ignighter could be bad. The oven will not light if the ignighter is not hot enough.
Sep 22, 2014 | DCS RGT-366-L
Ford taurus clutch engaged fans working feron loaded still blowing hot air brand new compressor
Orfice tube could be clogged. Have the low and high side checked.
Jul 03, 2013 | Cars & Trucks
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Haywood h400 pool heater, flames coming out of flue
check gas if ok clean burners make sure it is a propane unit if a N in model number it is natural gas orfices incorrect and will overheat very dangerous
Sep 09, 2012 | Hayward H Series Pool & Spa Heater 400k...
What's your problem? goodman furnace lights, burns 10 secs goes out
Hello,sounds like you have a dirty flame sensor. This is a metal rod on the oppositenside of the hot surface ignitor. turn off power to the furnace and remove the flame sensor, then use steel wool and clean the flame sensor and reinstall. Next turn back power to Furnace.
Nov 18, 2011 | Goodman Heating & Cooling
The oven doesn.t go on, I see the ignighter turn on but the gas won't light.
Hello Jim,
Believe it not the igniter is the problem,yes indeed it is coming on yet it is not getting hot enough to allow the gas valve to open. By replacing the igniter with a fresh strong one, the oven will work just fine.
GENE
Nov 14, 2011 | Kitchen Ranges
It will not get hot the front burner will light but when you turn the back one on it wants to go out. Was working fine until I put a new tank on the grill.
check the burners see if they need a clean or the orfice turn tank off open burnes let gas out turn off turn tank on slowly see if this helps
May 20, 2010 | Weber Genesis Silver A Grill
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
94 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
