SOURCE: 1989 ford f150 cranks over but wont start, have
does fuel pump run when you turn key to the run position...open gas cap stick in a funel put ear to funnel.. have some one turn key to run position......does check engine light come on when key in run position.......they have two very common problems....first the fuel pump relays and next very common problem is the ground for the ecm...main computer.....look at the battery then look at ground or negative wire you wiil see a smaller wire comming off the terminal. these will got to a bullet looking connector...cut out this connector and hook wires directly. even if not your problem it will be one day...write back if more needed
