Question about Sony Handycam CCD-TRV57 Camcorder
My handycam works fine with a np-f550 3 hour battery. With the np-750 6 hr battery it starts out okay but then 5 minutes later the charge drops to zero... is he battery bad? It charges up fine.
  • 72 Answers
Dear
np-750 ur mentioning ....n other you r using is np-f 550
ther is allot of difference in both of the model npf stands for info lithium battery ....
make sure 1 st that other one is also NPF
if yes, then your battery is faulty cells in battery has become week.
Posted on Jun 30, 2009
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Hi, I have a sony handycam hdr-cx160 with I bought a np-fv70 battery and my problem is that my camera turn off after I spend some time used it, Like 2 or 5 minutes. it is charged, the camera recognize the...
Hi luismasramir ,
Seems to be the case where the battery is not fully recharged , Please follow the below steps :-
  1. Please make sure that you charge your battery fully , till the time you see an indicator for the battery being fully charged , or may be you see an icon in the display screen with the charge status.
  2. As far the 6.30 hr duration that you have mentioned, this duration reflects the time that you have left for total recording space on your disk or memory card depending on your current source for recording.
  3. The above duration is not to be confused with the battery usage time.
Hope his helps ...:)
May 11, 2011 | Sony Handycam HDR-CX160 Camcorder
I have used my Sony Handycam DCR-SR40 and the battery went dead. I then charged the battery several times and still won't turn on. I even attach the camcorder to the Sony base and connect it to the...
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 06, 2010 | Sony Handycam DCR-SR40 Camcorder
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
Battery not getting charged
you must check the power cord of your ac adaptor too then check if it has a fuse. you can change the fuse or change the power cord.
Sep 28, 2009 | Computers & Internet
It worked fine one minute and about 10 minutes later it would not turn on at all. Batteries not the problem as plugging it into the power cord or the computer hookup does nothing.
Its because ur internal memory battery is dead or no charge so please keep the unit charge in all possible ways for about 2 hours. Some palm tops have base stand and a seperate place on the base stand to charge the normal battery. So make sure u leave the unit for charge for a longer period of time say 5 hours.
Thankyou
Jul 31, 2009 | Palm Z22 Handheld
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
New batteries will not charge
a technician ' s adjustable bench power supply - set for 9 volts at 1 amp - for a minute or so , will initialize most new lithium batteries ( a charger update may also be available ) ;
Sep 18, 2006 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony Handycam CCD-TRV57 Camcorder Logo
83 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
