Question about Dryers
GE dryer heating problems
Dryer will heat fine and the next time it will hardly heat at all. Just comes and goes.
  • 6,784 Answers
Check the following.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Posted on Jun 25, 2009
Dryer wont heat
either the element is bad our the diode that controls the heat element is bad
Jul 04, 2012 | GE Dryers
Dryer runs fine but no heat, igniter visably looks fine.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 26, 2011 | GE Dryers
My gas dryer only heats occasionaly - sometimes will work all day, sometimes only will heat one load and not heat the next. Any suggestions?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | GE DPGT750GC Gas Dryer
I have a gas GE dryer DPGT750GCWW ;- it only heats occasionally. Sometimes it will work all day, other times it will heat one load and won't heat up for the next load. The vent has been cleaned...
heatman101
Dec 18, 2010 | GE DBXR463GB Gas Dryer
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
My GE Harmony dryer has stopped heating. All of the cycles work (air comes out), it just wont get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | GE Profile Harmony DPGT750EC Electric...
The vent was 90% crimped for a long time. The dryer heat comes and goes. Does a digital compputerized dryer have a thermal fuse that you can replace?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 25, 2010 | GE Profile Harmony DPGT750EC Electric...
I HAVE A GE DRYER THAT WAS WORKING FINE ONE LOAD THEN STOPPED HEATING UP ON THE NEXT LOAS.IT TURNS FINE BUT NO HEAT
either your heating element,cycling heat switch,hi-limit switch,or thermistor are defective also check power input for 240 volts,if one leg 120 volts is missing it won't correctly
Oct 31, 2009 | GE DVL223EBWW Electric Dryer
Dryer not heating
heatman101
ryur
Sep 17, 2009 | GE Spacemaker Washer and Dryer Electric...
Dryers Logo
71 people viewed this question
Top Dryers Experts
