Question about GE JTP20 Electric Single Oven
F7 error on GE eledtric oven JKP20
Error message beeps. No oven controls work.
  • 6,784 Answers
This is a shorted touch pad. replace the touch pad or, if the touch pad is incorporated within the control board, replace the entire oven control board.
Posted on Jun 25, 2009
F76 error code on ge oven
One of the most common problems with GE electric built in ovens is the error code "F7? shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4? nut driver and a Phillips screwdriver. - See more at: http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/#sthash.pVUT3Nzb.dpuf
Oct 14, 2013 | GE Ovens
I have to turm the oven off at the braker box. it comes on by itself. when I turn it on to cook it will not stay on gos off and beeps. Shows C7 or F7
This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards, Diana
Jun 15, 2010 | GE JKP20 Electric Single Oven
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
What is error message F7 mean in GE Wall Oven?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jan 31, 2010 | GE Ovens
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F7 error
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
GE JTP20 Electric Single Oven Logo
268 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
