Wont go full throttle in forward gear
SOURCE: 3.5 mercury outboard stalls when put into forward
hi take the prop off see if there is anything /string/ between the hub and the housing check oil lvel in g/box /is gear box nice and free if all is ok try it in ware with just a small amount of choke
drain /empty fuel out replace with fresh /correct oil mix
check /change fuel filter/air filter
warm engine up check idle mixture ajustment/tick over speed
increase idle speed slightly/7/800 rpm
hope this helps merlin v 12
SOURCE: 4 stroke 6hp mercury outboard -brand new first
????? Was the dealer using his fuel tank or yours.Might be a blockage or contaminate in the fuel tank.Hope this helps
SOURCE: Gear shifter locked in forward gear
If the gear lever is loose,it's the gear connection rod that you disconnect to do a g/box drop.If its not loose, drop the g/box off the leg and the first thing you find might be the problem.A loose bolt,a jammed shifter.It will probably be a connection problem than a g/box problemHope this helps
Maybe the transmission went out. Take the bottom plug from the lower unit and see if it is full of water or lots of metal in the oil. THEN take a magic marker or a punch and hammer and mark the hub of the prop opposite the blades of the prop and go run it again. If the marks move from one another, you need to have the prop repaired.
SOURCE: Why would an outboard motor stop in full throttle and barely go except in reverse
You might have hit something and ruined the prop.
