Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Duplicate straps for a great many inexpensive fashion watches are not available and either a universal strap or bracelet used or the whole watch discarded or replaced. Sometimes a junk shop or thrift shop will yield something salvaged that could resemble the original. Sometimes jewellers and watch repairers collect junk watches for parts so asking around locally could bear fruit.
More expensive watches might have replacement straps or bracelets available from the manufacturer or dealer for a limited time as a spare part.
Replacement straps or bracelets should be available for the best watches from the manufacturer for a considerable time.
Unless your watch is a Rolex or an Omega or similar I suggest you start your search at your local watch repair shop.
Depending on what brand you are seeking, I stock a great many. The Rolex oyster bracelet being very popular and one of my best sellers. I can supply bracelets for any watch. If the factory made it, I can get it. Email me [email protected] Have added some pics of the Rolex bracelets
The watch part number and a knowledgeable watch maker will provide the correct bracelet. If you WANT a leather strap most models can accept one - unless the case is sculpted to integrate seamlessly with the bracelet, in which case you may not be able to insert the spring bars that are necessary to mount the strap.
mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
Measure between the lugs, (where the currently installed bracelet/strap is installed. It should be measured in millimeters as that how all straps/bracelets are measured. Standard men's widths are 20, 22, 24 and some 26mm. There are of course, variations like proprietary bracelets and straps made to fit watches which will only accept the proprietary size made for it. These are usually much smaller (18, 14, 16mm) and integrated into the watch body design.
I'm guessing you have a watch with a expansion band that has removable links.
I'm also guessing it has a snap fastener and you have already made your band smaller through adjusting that part of the bracelet.
I'm guessing that yours is of a similar design to several I have owned and/or adjusted for others.
I'm guessing you have a paper clip in your home or office and ...
I am also guessing you never thought of a paper clip as a tool.
Straighten one leg of the paper clikp and pop out the little keeper on two of those links, reattach the loose ends for a smaller bracelet. There should be a little arrow pointing in the direction you should push the little clip/keeper.
I hope this helps you make your bracelet the size you need it to be.
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
