Question about Luhr Jensen Little Chief 9800
Lil Chief Smoker trips GFI plug
I have a brand new never been used Lil Chief smoker w/250 watt element. The unit trips the GFI immedately when plugged in. There are not other appliances plugged into the circuit. What's up?
  • Anonymous Mar 18, 2014
    look for a heat element
    Problem Solver:
  • 11 Answers
There is a short somewhere in the unit. Return it ASAP!
Posted on Jun 26, 2009
Why after five minutes or so of becoming hot does the grill trip my power
When you say power I am guessing you mean the ground fault switch. Struggled with that myself until recently. There are a lot of posts out there of people with this problem with a variety of smokers. Try plugging into an outlet not protected by a ground fault outlet. If the smoker works that way (mine did) I would suggest you replace the electric heating element. For $30 bucks or so this fixed my smoker. Found my part on appliancefactoryparts.com. My smoke is a Masterbuilt brand. Putting the new element in was pretty easy but a bit messy. Look for a video on YouTube for your smoker.
Good luck and happy smoking.
May 07, 2016 | Grilling
I need a new electric heating element for my Little Chief smoker
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
Jan 15, 2013 | Grilling
Bought little chief model 20 smoker don't know how to use it...
The Little Chief smoker, manufactured by Smokehouse, is available in front-loading and top-loading styles. Both models are electric, depending on a 250 W electric heating element to supply the heat. The smokers can accommodate a maximum of 25 lb. of meat or fish. These smokers are for outdoor use only, and plug into a 120 V AC electrical outlet.
  1. Brining
    • For extra flavor, treat your meat, poultry or fish to a brine bath before smoking. Use 1 cup of kosher salt for each gallon of water. Consider adding molasses, spices or even a pureed jalapeno pepper or two into the brine solution. Leave thicker pieces of meat in the brine solution overnight. Fish only need to be soaked in brine for around four hours.
    Wood Chips
    • Mesquite and hickory are probably the two most widely used woods for smoking, but apple and pecan wood can give your smoked foods another tasty dimension. As with anything else, experiment to create your own favorites.
      Smoker wood is sold either as chips or chunks. Use large chunks to smoke thicker pieces of meat; the chips will be spent before they have thoroughly smoked the meat. You can continually replenish the chips, perhaps every half hour, for as long as you wish to smoke the food, but the job can be tedious with a large roast that takes hours to smoke.
      Smoke the wood well before it is introduced to the heat. Chips will be completely soaked in a half hour, but chunks of wood will require an overnight soaking before use.
    Smoking
    • When your meat is thoroughly brined, and the wood soaked, carefully lay out the meat on the smoking racks. Make sure that there is some space between each piece. Place fish on the rack with the skin-side down. Drain your wood and place it into the smoker on top of the heating element. Use the small pot that is provided to keep moisture or collect juices. Place the racks into the smoker and close up the box. Plug in the electrical cord and within about 10 minutes, you should see smoke gently trickling out from the smoker's vents. The thicker the food inside the smoker, the longer the process will take.
    Mar 18, 2011 | Luhr Jensen Little Chief 9800
    My smoker keeps tripping my ground fault receptacle. I plugged in other items and i had no problem with tripping the ground fault. I also had to change the female connector going to the heating element.
    If nothing else is tripping your GFCI, then there is a short somewhere in the wiring of the smoker. Check the female connector you had to replace, as well as that particular to see if you can detect any melting of the insulation or a bad connection of the other end.
    Typically, electric smokers use high heat resistor wiring. So, something in the wiring is not like it should be. Or it may be the heating element itself. If it's still under warranty contact the manufactirer.
    Feb 06, 2011 | Masterbuilt 20070106 Electric Smoker
    My electric smoker keeps tripping breakers
    My Brinkmann 810-7080-4 Gourmet Electric Smoker was tripping my GFI after it sat for the winter. Would heat for about 3 minutes then trip the GFI. would keep tripping GFI until it cooled down and once again would trip after about 3 minutes.
    --SOLVED: took 00 steel wool and olive oil to the heating element and removed what looked like a green fungus. Element is working fine now, not tripping the GFI and will run a full four hours for smoking!
    Hope this helps save someone some money in purchasing a new heating element ($40).
    Nov 26, 2009 | Brinkmann Smoke' n Grill Electric Double...
    Big Chief smoker trips 20 amp GFCI
    try to use another out let and see if it is the GFI outlet first if it trip the new outlet then you know it the grill and not the outlet
    Jul 31, 2009 | Luhr Jensen Big Chief 9890
    I have a little chief 9800 top load smoker and lost the heating element in a move. There are two elements available, a 7.5" and an 8.5", but I'm not sure which size my smoker takes. Is there any way to...
    The #4 Little Chief element is 7 inches and more importantly is 250 watts, this is the correct wattage for ALL Little Chief Smokers newer than about 15 - 20 years old.
    The #5 Little Chief element is 8.5 inches and is also 250W but is for newer models before 2006.
    Look at www.smokehouseproducts.com for clarification & best fit.
    For very, very old models (20+) there is a ceramic disk (175W) that heats the chip pan and is hard to find and expensive, a person would be better off finding a new one on sale at the big box boys store
    Jul 07, 2009 | Luhr Jensen Little Chief 9800
    My little chief smoker never got the fish I was smoking to 140 deg.I had this unit smoking for two & half hrs. is this normal?
    How old is the smoker? Is the heat element old, weak (maybe needs replacing?) Did you save the cardboard box the smoker unit comes in and place it over the smoker for the actual smoking process? This is recommended by the manufacturer and keeps the smoke and heat in, and gets you up to temperature. see also www.smokehouseproducts.com
    Jul 02, 2009 | Luhr Jensen Little Chief 9800
    Replacement Parts - Lil Chief
    Try www.smokehouseproducts.com or any Cabela's or Sportman's Whorehouse, I mean Warehouse or any big box sporting goods store in general. The heating element is a hard one because it's probably the old style ceramic disk. We have two like that. They run on 175 Watts instead of the newer 250W using the "O" shape elements. They're $29.99 + s/h, we want to try to convert ours to the newer 'O' shape if possible. The elements are around $12.00 at Wally World. Best of luck!
    Jan 31, 2009 | Luhr Jensen Little Chief 9800
    Grilling Logo
    618 people viewed this question
    Top Luhr Jensen Grilling Experts
    Paul Carew
    Gary Kenady
    Gary Kenady
    Dan Webster
    Dan Webster
    Are you a Luhr Jensen Grilling Expert? Answer questions, earn points and help others
