Question about Whirlpool Dryers
GAS DRYER TAKES TO LONG TO HEAT UP
RECENTLY I HAVE TO PUT MY LOAD OF CLOTHING 3 OR 4 TIMES BEFORE IT HEATS UP...OR IF I PUT A COUPLE OF THINGS IN THE DRYER IT DRYS THEM
  • 6,784 Answers
Check the following to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Posted on Jun 25, 2009
I have a gas GE dryer DPGT750GCWW ;- it only heats occasionally. Sometimes it will work all day, other times it will heat one load and won't heat up for the next load. The vent has been cleaned...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | GE DBXR463GB Gas Dryer
My dryer heats up,, glow works, igniter works,, then cycles approx 3-4 times then stops cycling
heatman101
Oct 18, 2010 | Whirlpool LGV4634JQ Gas Dryer
Amana Dryer NDG5805AW heats for a couple seconds after starting then no heat HELP
heatman101
Sep 08, 2010 | Amana NDG5805AW Gas Dryer
The dryer heats but not enought to dry the clothes... I have to run it about 5 to 7 times to dry the same load.... what could it be?
heatman101
Apr 26, 2010 | Roper REX3614KW Electric Dryer
Heats but does not have high heat. Takes about 80 min. to dry a average load of clothes. Dryer will heat up but does not get hot enough
have you checked to be sure you venting is clear leading to the outside of you home. obstructed venting will form your dryer to shut the heat off prematurely with then result in long dry times.
if it is a gass dryer, the the gas valve coils could be goind bad but check the venting first.
Mar 22, 2010 | KitchenAid Dryers
Dryer heats for only !st few mins.
there are different temp setting Thermostat ,check to make sure the right one was installed. recheck element continuity
Apr 09, 2009 | Dryers
Dryer takes hours to dry ever since I converted to propane.
check for obstuction such as lint build up in the exhaust tube all the way out the house. Sounds like poor air flow
Mar 01, 2009 | LG DLG7188 Gas Dryer
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Dryers Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
