Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I have an old Homelite ez with a Walbro HDC 44
I have an old Homelite ez with a Walbro HDA 44 carburetor. Engine is getting to much gas and is flooding out
  • jsaroka Jun 25, 2009
    I have an old Homelite EZ chainsaw with a Walbro HDC 44 carburetor that is flooding. What is wrong?
    Sergeant:
  • 353 Answers
Try running without filter to see if problem persists(no cutting)
if not cleaning the air filter or replace
Posted on Jun 25, 2009
    Top Expert:
  • Husqvarna Master
  • 81,400 Answers
THE MOST LIKELY CAUSE OF THIS IS EITHER A PIECE OF DIRT IN A CARBURETOR JET OR A CHOKE BLADE THAT IS NOT FULLY OFF, IF THE CHOKE IS OK THEN REPAIR THE CARBURETOR.
  • Marvin
    Marvin Jun 25, 2009
    I have been doing this 40 years and you need to overhaul the carburetor this is a dirt problem in one of the tiny jets
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Dersoj@bellsou5th.netI have a Walbro "49"
Look on your carb and find out which of these numbers is stamped on it:
CAA
HD
HDA
HDB
HDC
LMB
LME
LMG
LMH
LMJ
LMK
LMR
RWJ
SDC
WA
WB
WG
WGA
WHG
WHL
WIP
WJ
WLA
WPF
WS
WT
WTA
WTE
WTEA
WY
WYB
WYF
WYJ
WYK
WYL
WYM
WYP
WZ
If you provide your engine model number I can find the diagram on your carb and figure out where the coned shaped rubber piece is to be installed.
Kelly
May 05, 2011 | Garden
Homelite 240, runs but shuts off......... I suspect carburator.....
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. Make sure the carburetor is fastened securely to the engine. If you still have problems, go to: http://www.drystacked.com for a 12 page article on Walbro carburetor theory and troubleshooting. This information applies in a general way to other carburetor brands as well. Hope this helps!
Nov 05, 2010 | Homelite Garden
Homelite starts with strarter fluid and then stops
Does the pumper bulb fill with fuel when pumped? I had a similar problem with a Homelite--which turned out to be the location of the carburetor lower-chamber gasket. The diaphragm needs to go to the carburetor body (pin inward), then the gasket and cover plate. Go to:
www.drystacked.com for a 12 page PDF document on Walbro carburetor theory, troubleshooting, and repair. Hope this helps!
Mar 29, 2010 | Homelite ZR10926 16" Chain Saw
There is a half circle-like part which helps the gas to circulate when starting the motor, the plastic thing has a hole from which the gas leaks whenever attempts are made to start the engine. What is this...
Sounds like you are talking about the primer bulb. It is replaceable, Find a shop that can sell you a primer bulb for a Walbro carburetor or take the unit with you and they should be able to match it up.
Good day.
Nov 07, 2009 | Homelite Factory Reconditioned 26cc...
My homelite tiller stalls after 30-60 seconds of running. i changed plug and checked filter. gas is new
I'm assuming a 2-stroke engine. Does the fuel system have a primer button? Assuming that the answer is yes, the carburetor is not pumping fuel, but starting on the primer charge. Is the carburetor a Walbro brand? If so, got to: http://www.drystacked.com for a 12 page PDF on theory and repair of these carburetors. If the primer works, the main fuel line should be ok.
Sep 17, 2009 | Garden
I have an old Homelite ez with a Walbro HDC 44 carburetor. Engine is getting to much gas and is flooding out
THIS IS CAUSED BY A PIECE OF DIRT STUCK IN AN AIR BLEED JET OF THE CARB OR THE CHOKE BLADE NOT BEING FULLY OPEN, CHECK THE CHOKE BUTTERFLY 1ST, IF IT IS OPEN ALL THE WAY THEN REMOVE AND CLEAN/REBUILD THE CARBURETOR
Jun 25, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
175 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
