Question about Sony PlayStation 2 (PS2) Console
Can i format an old playstation 2 memory card
  • 149 Answers
I think you have to manually delete everything off of the memory card, There isn't a format option on a PS2. I havent got my adapter for my PS3 yet to see if I can format the memory card on the PS3.
Posted on Aug 09, 2009
Format issues!
I had the same issue on 11 different cards.
(all were OLD)
I bought a new one and there was no problem.
Nov 06, 2013 | Hyperkin PS1 Memory Card 1MB
Tip
How to format PS2 memory Card for use.
Insert the PS2 memory card into the first memory card slot on your Playstation 2. Make sure that the card is all the way in the slot the card may not register when you turn on your Playstation 2.
Turn on the Playstation with no game or DVD inside of it. Wait for the main menu to pop up on your television screen.
Using your PS2 controller, highlight the memory card option and press the X button. This will open up the memory card menu, which will allow you to delete data or transfer data from one memory card to another.
Wait for the Playstation 2 to send you a prompt asking you to format your new memory card.
Click "Yes" when the formatting prompt appears on the screen. This will automatically format and set up your new memory card for use with your
on Feb 14, 2010 | Video Game Consoles & Games
Ps2 not recognising memory card
Try formatting the card. If formatting the card doesn't work, either the reader inside your PS2 is broken, or the card itself is damaged somehow.
Jul 05, 2012 | Sony PlayStation 2 8MB Memory Card - Black
I bought a new ps2 and a datel 32mb card and the game i put in says there is no memory card,
Try these steps. If this doesn't work you may want to take the card to Game Stop or something and have them test it to see if it's working. Hope this helps!
  1. Insert the Memory Card into the PlayStation 2 console. The port is located directly above the controller port. Note that there are two different memory card ports; there is no difference between the two. Some games, however, will attempt to auto-load from slot one so it is recommended that you keep your memory card inserted in slot one.
  2. Plug your controller into the PlayStation 2. Power up the system without a PS2 disc inserted. You will be taken to the system menu screen. Select the "Memory Card" menu to examine any data on the card. If the memory card is new there should be no data on the card, if it is used you may see old saves from the previous owner on the card. If you no longer desire to keep these saves, you may highlight them and press the "Triangle" button to delete them.
  3. Insert your PlayStation 2 game disc into the system. When the disc appears on the system menu, select it. Load the game, and play until you are prompted to either create a user profile, or to save your game. Once you have saved any data to the memory card, reset the system.
  4. Select the "Memory Card" menu and examine your memory card. You should see a new icon representing your game's save data. If this data appears on the card, you have correctly set-up your PS2 Memory Card.
    If the data does not appear on the card, you will need to format the card. If the system detects corrupt data on the card it will automatically open a prompt asking if you would like to format the memory card. Select "Yes" and the PlayStation 2 will format the card.
Dec 31, 2010 | Datel Max Memory 32MB Memory Card
Can not create internal memory card, whenever I try I returned back to the screen that says name a internal memory card.
http://ps3explained.com/intermediate/internal-memory-cards/
Create an Internal Memory Card on the PLAYSTATION 3 system HDD as follows:
1. Navigate to [Memory Card Utility (PS/PS2)] under [Game] on the XMB.
2. Press “X” to bring up the “New Internal Memory Card” option.
3. Tell the PLAYSTATION 3 which format you want it to create. PS2 or PS1.
4. Highlight “OK” and press “X” to finish creating the memory card.
Note that you can make new saves on this card while playing PS2 or PS1 games on the PS3, but it does not allow you to transfer saves from a physical memory card to the PS3's HDD. You need the memory card adapter to do that.
Apr 06, 2010 | Sony PlayStation® 3 (80GB) Console
My son is attempting to save a game (SPYRO Riptos-Rage). Error shows "Memory Card is not inserted." We just bought a new one today because we thought something was wrong with the other one. One is 8MB the...
You may need to format the card first before you use it.
PS2 Memory Card "Unformatted"
DNT FORMAT IT if you do then it will just unformat its self when you turn it back on i have the same problem if i was you i would try deleting some stuff off the memory card (turn the play station on with out a disk in and click on memory card) than delete some old data you dont want. but if that still dont work then try blowing in the memory card (it might be a bit old). after you have done all of these things and it still dont work then i would go on a website about sony play stations and unformating memory cards, and there will be a phone number ring it tell them whats happened and they will surly send you a new memory card but that would meen your old memory card would have to go in the bin :( its a plesure to help.
May 30, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 slim (sliver) just decided to not reconize the memory card
try to push the memory card upwards while inserted...but not to strong...it might break..it happened to my old memory card..
May 05, 2009 | Sony PlayStation 2 Slimline Console
Not compatible with new game
The problem is that the disks made by various manufacturers and in consists o different file formats.Therefore it is only possible when you have the same manufacturor disks of same batch.
Thanks
Sep 28, 2008 | Sony PlayStation 2 (PS2) Console
Have to format memory card
enter the memory card and select corrupt data
Jan 26, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
210 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
