Question about Garden
Annovi pump wont build pressure
Unloader is clean and it work fine then quit and never built pressure again . thought the valves in the Head amy be dirty but ima afraid to remove until I get advice Problem is annovi pump wont build pressure
  • 32 Answers
Try force feeding the pump first, this can help to clear any dirt which might be in the valves.
you have 6 valves which are all the same , but 3 are suction and 3 are for pressure.
just take them out and put under a slow dripping tap and fill with water, if the water holds inside the valve will be ok, if it leaks just check for dirt.
hope that helps
Posted on Jul 04, 2009
No pressure build up from pump
looks like this is a small triplex pump.ensure the pump is acually turning over with the power unit and the love joy coupler is working properly and there is no stripped out key ways ect. was the hose jumping before the loss in presure? this could indicate a washed out in the intake or dischage valve. or debris hung up there in. check the pressure relief valve/unloader valve for proper function may be the pressurised water stream from the hose is by passing .repair /replace as required.
Aug 30, 2014 | Honda Gx270 9.0
High pressure wont shuy off
do you mean it keeps trying to build pressure even when you release the trigger on your wand???that is a problem with your unloader....also checkout your shutter valve and replace the oring on it. You will need the diagram here to know what parts Im talking about Pump Breakdowns and you can order parts here Pressure washer parts catalog quick links Pressure Washers High Pressure...
Jul 19, 2014 | Annovi Reverberi 2400 Ar Pressure Washer...
Low Pressure
Very little info to go on here. Could be a valve issue or a packing issue or an unloader issue. If it has been sitting for any length of time which tends to be the case, then an unloader valve is most likely the culprit. Good luck
Apr 19, 2014 | Annovi Reverberi Rmw 2g24 Vertical Shaft...
Pressure washer pump pressure kills gas motor
the pressure regulator valve is stuck take it apart and clean it
Jun 04, 2012 | Annovi Reverberi Sjv3g27d Pressure Washer...
I have a vt631401aj campbell hausfeld compressor. when it builds pressure to 135 psi, the compressor shuts down and immediatly starts dumping air until it goes down to 90 psi. It then stops dumping the...
John: I had a similar problem with a brand new CH-made compressor. The problem was not with the unloader valve, but with the check valve located where the air from the pump enters the tank. The check valve was not seating correctly due to brass filings from manufacture. The defective check valve was allowing air to escape back the wrong way from the tank to the pressure switch and through the unloader valve. This backflow from the tank would start to happen when the pump stopped after reaching high pressure. The back flow would continue until the pump restarted at the low pressure point. This cycling would continue as you described. Once I cleaned the check valve, everything (including the unloader valve) started working correctly. I hope this helps. And remember, don't work on these when they are under pressure and always wear safety glasses.
Sep 18, 2011 | Campbell Hausfeld Air Tools & Compressors
Annovi reverberi triplex preesure washer pump
Usually when a pressure washer is pulsating, either one or more pistions are not pumping. Quite often one of the check vavles for a cylider has broken and will not seal, which means you'v just lost one cylinder, and now you're running on two (etc) If a pressure washer is allowed to idle too long, re-circulating the water, it will get hot, and then melt the plastic container on the check valves. Go to : www. pressure-washer-parts.com You can order parts, and manuals.
Jul 15, 2010 | Annovi Reverberi 4000psi 4gpm Pressure...
Compressor wont restart because of head pressure
Piston air compressors have to unload to permit a restart, the two mot common types are an unloader valve or free air unloaders.
with an unloader valve this system uses a check valve mounted in the discharge line as it enters the tank, when the pump stops this check closes and does not permit the tank pressure to return to the pump. a unloader valve also opens to allow air pressure in the discharge line to vent, this valve is either on the pressure switch or on some models is on the pump, and is a centrifugal type.
Free air unloaders or head unloaders are a set of fingers that hold open the intake valves on the cylinders to permit the piston not to pump air against a head load, and once the pump is running the fingers retract to allow the pump to function as normal.
Jan 19, 2010 | Air Tools & Compressors
I have a troybilt pressure washer when i crank it up it builds pressure when i engange the pressure it takes about 5 seconds and pressure goes away if i let off the trigger it will build pressure again it...
Unloader valve is the most likely suspect here.
Remove and clean with penetrating oil then reinstall.
Also add some LIGHT oil into your supply hose via a small funnel. 3-in-1 household oil or power steering fluid lubricate the valve and pump quite well. Three or four treatments of a couple ounces each will usually make the pump happy again.
Hope this helps!
Sep 27, 2009 | Garden
Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Jul 22, 2009 | Honda Garden
No pressure unless i take the nosle off , pull trigger and put nossel back on then it's ok until i release the trigger again ?
unloader valve sticking in the pump head. remove unloader valve/ pressure reducing valve as per parts manual.
It will probably be caked up in white crystal type deposits if its an aluminium pump head. clean off the deposits and inspect the 'o' rings. if 'o' rings ok , apply silicon grease and refit.
It could also be a partially blocked lance jet not allowing enough water to come out of the lance if it is a flow sensitive unloader valve.
Jul 11, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
317 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
