Printer message apears "change tray 1 plain letter" when i press print. will not print until i press select. Ive tried changing printer setting and cant seem to fix it..
  • Office Equip... Expert
  • 398 Answers
Change the paper type at the printer to plain letter, or in printer properties from the start menu.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
HP laserjet p3005 it was working ok as we don=ont change the settings often. From yesterday, as soon as we give a print command, it gives a message "LOAD TRAY 1 LIGHT LETTER, then when we press green...
This is a settings problem, you will need to go through the paper handling menu on the printer and on your computer to ensure they are set to the correct paper size that you are trying to print on.
Aug 10, 2011 | HP LaserJet P3005 Printer
Lexmark e352dn-load manual plain letter message
In most cases if the printer is asking for an unexpected manual feed it is because the paper tray is not set to the right paper size or type. To set the paper size to the most common size and type (letter size plain paper) use the following instructions.
1. Press the Menu button.
2. Press the right arrow key until Paper Menu then press Check Mark.
3. Press the right arrow key until Size/Type then press Check Mark.
4. Press the right arrow key until Tray 1 then press Check Mark.
5. Press the right or left arrow key until Letter then press Check Mark.
6. Press the right or left arrow key until Plain then press Check Mark.
7. Press the back button until Ready is displayed.
This will set up your printer tray for plain letter paper and should relieve the manual feed error unless yourcomputer is sending other paper size/type settings.
Aug 20, 2010 | Lexmark E352dn Laser Printer
Everytime we print we get a beeping sound and an error message that says Change Tray 1 Plain Letter. If we press select, it will print
In the printer setup menu. You need to change the paper type for tray 1. It's likely set to a different type of paper (maybe card stock?).
The printer driver will specify what type of paper is being used, and the printer doesn't know what type of paper is in it other than what it is told, so a conflict occurs.
Oct 13, 2009 | Dell M5200n Laser Printer
Printer does not recognize that there is paper in the tray
Using the printer panel; you need to change tray paper size from a4 to letter or the size you are using to print on.
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
An astrick will appear to the right of the size paper that the printer currently has selected.
Apr 03, 2009 | Dell 3000cn Laser Printer
I need to reset the default settings on my Lexmark Optra S 1625
It sounds like they changed the Paper Type in the menu settings. I cannot remember 100% where it is on this model, but if you go through the menus, you should come across a Paper Menu option. In this menu, you need to change the Paper Type for Tray 1 to Plain Paper.
Feb 25, 2009 | Lexmark Optra S 1625 Laser Printer
WON'T PRINT
There is a Paper Menu option somewhere in the menus on the op-panel. You need to go to the Paper Type option and change the Paper Type for Tray 1 to plain paper. You can also hit the Select button when you get this message and you will print.
Feb 19, 2009 | Lexmark T644 Laser Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Load MPP Letter Plain 1
when printing, select the cassete tray. it is asking to load paper on the manual tray on the front, so it keeps asking until you put paper there
hope this helps
thanks for your rating
Jan 07, 2008 | Dell 3000cn Laser Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
310 people viewed this question
k24674
jasbo
jasbo
