Iomega Home Media Network Hard Drive TB Won't connect and print.
I have a Iomega Home Media Network Hard Drive TB, and I can't get it to consistently stay on the network. I initial set it up fine and copied 40 gigs off my mac (10.5.7) onto the drive. And then I connected my PC laptop (XP Home) to it no problem. But when I connected a printer to it It stopped working and now nothing can see it. I took off the printer and it still won't work. I got this drive for storage, but I also really like the print server option, How do I get both to work? Thanks for any help.
5 Suggested Answers
JUGGALOTUS
  • 151 Answers
SOURCE: Purchased new Iomega 1 TB Home Media network HD,
you have to initilize the disk in disk management utility, heres how (windows XP)
  1. Click on Start and then Control Panel.
  2. Click on the Performance and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Just double-click on the Administrative Tools icon and skip to Step 4.
  3. In the Performance and Maintenance window, click on the Administrative Tools link located under the or pick a Control Panel icon heading near the bottom of the window.
  4. In the Administrative Tools window, double-click on Computer Management.
  5. When Computer Management opens, click on Disk Management on the left.
    In a few seconds, Disk Management will load on the right side of the Computer Management window.
    Note: If you don't see Disk Management listed, you may need to click on the + icon to the left of Storage to expand the option.
  6. You can now format a hard drive, change a drive's letter, partition a hard drive, or do whatever else you need to do in Windows XP's Disk Management tool.
Posted on Dec 11, 2010
  • 74 Answers
SOURCE: I don't know how to make a wireless connection
Make sure you are at least using a CAT 5 cable with your device. You will want to do a couple things as well. Give your device a static IP address (manually configure the IP) from withing the devices interface (login to your device, System tab on the left and Network tab on the right). Next go to your folders you are wanting to share and click the DLNA button that corresponds with the folder you are wanting your media server to share out. You should be good to go.
Posted on Dec 24, 2010
SOURCE: I installed the Iomega 1tb
Check tcp ip settings of your harddrive. Make sure it is in the range of your local network. check the ping command from computer if you get reply then it is in network. Then you can use it. Make sure network cable is fine. Let me know if you need further assistance. Thanks for using FixYa.
Posted on May 17, 2011
SOURCE: Iomega homwe media network drive - How do i map
Simple type the Ip address of the NAS Drive in the RUN window of your windows pc and hit enter.
Now all the shares appears right click the Share u wish to MAP and select MAP network drive.
That is it.
eg:in run type \\192.168.10.177 then replace the 192.168.10.77 with your address.
Posted on Aug 16, 2011
Iomega Home Media 1 TB Network Attached Storage 34337 pingable but unavailable
So when you plug it in the a USB port it isn't found by windows?
Option: If you can remove the drive from the case, you can use a drive adapter that will allow you to access the drive itself. If the drive still can't be found in windows you can try Linux. Download Pinguy OS
If you can find the drive in computer manager? Then it might say it needs to be formatted. If you format the drive, you could then use a recover software like Recuva from filehippo.com (Worst Case)
Pinguy linux has great tools to help recover faulty drives also.
If this has help, please give me you vote..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 04, 2014 | Iomega Home Media 1 Tb Network Attached...
Corrupt Files?
once you have renamed a corrupt file , all your data will be forever lost, no way to retrieve them, unless you have back up copies of those files.
Mar 22, 2014 | Iomega 2 TB Home Media Network Hard Drive...
Iomega ez media slow to respond
For me, is a very bad option for buy. Very buggiest, slow and dangerous to use for your backups
Sep 06, 2013 | Iomega 2 TB Home Media Network Hard Drive...
How do i detect the ip of my iomega
you have two options:
1) Install the Iomega management software and it will detect the connected storage at your network automatically, then you will be able to view the IP address
2) connect to your router management console and check the connected devices; if your network is not huge you will be able to locate the device easily
Apr 22, 2012 | Iomega 2 TB Home Media Network Hard Drive...
Quikprotect is not able to connect to Iomega network hard drive, though it can detect it. I can see the drive in Windows Explorer and manually copy files to it. But I am not able to set target location in...
make sure you have the Lenovo storage manager software installed. Make sure you can see the device from the storage manager and all the shares. Once this populates you can then see the shares in quickprotect. I believe quick protect polls Storage manager rather than the actual network.
Aug 14, 2011 | Iomega 2 TB Home Media Network Hard Drive...
I don't know how to make a wireless connection with this device. 2 notebooks, 1 desktop, 2 Ipads, 1 PS3 and the Wii wireless connected and working the Printer and Iomega 1 TB Media Network Hard Drive are...
Dec 10, 2010 | Iomega 1TB Home Media Network Hard Drive...
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
I have a brand new Home Media network drive that wont install
Iomega Home Media Network Hard Drive User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hmnd/211-1009/en/index.html Downloadable User's Manual [232KB zipped HTML] http://download.iomega.com/manuals/hmnd-1009/html/en.zip Quick Start Guide [PDF 1.3MB] http://download.iomega.com/manuals/hmnd-1009/print/d31497002.pdf Specifications https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=20851&p_sid=V_3q12dk&p_lva=14432 ---------------------------------------------------------------------------------------------- Download the latest Manager software. Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
Sep 27, 2009 | Iomega Home Media Network Hard Drive 500...
Computers & Internet Logo
2,497 people viewed this question
Alun Cox
David Payne
David Payne
