Question about Mitsubishi WS-55809 55" Rear Projection Television
72" rear projection wont reset green light flashies but wont tron
Wont turn on when u reset green light flashes about 20 seconds then stops and set wont turn on
  • dswehla Jun 25, 2009
    rear projection mitsubishi wont turn on ,when reset the green light flashes about 20 sec. but set still wont turn on
This normally happens after a power failure. This set should have 4 capacitors. The flashing light usually indicates that these capacitors will need replacement. They changed the value of them to prevent them from failing again. I believe they are 16V 1500uf and you should be able to get these repaired by a service technician.
The capacitor issue is a very common occurrance with this model of TV. This link has some more information about their replacement.
Thanks
nLinked
Posted on Jun 25, 2009
    President:
  • 2,923 Answers
Try unplugging the power cable for 15 minutes and try to turn the rear projection ON. That might reset the projection TV.
Here are the things that you need to check:
1. Make sure that the plug is connected to the wall outlet.
2. Check the power supply - you might have a bad power supply we cannot be sure without testing. If you have an experience with electronics, you may want to test it.
3. Check the Convergence IC - to test/check the convergence IC, you might need an assistance from the expert
These are the things that you need to check and you may need to contact the manufacturer for repair if the rear projection is still under the warranty. If not, refer to any authorized repair shop.
Hope it helps and have a great day!
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv keeps turning off.
Hello there please check the following in your tv;
Reset the component settings. Most problems with Mitsubishi projection televisions can be resolved by resetting the television to factory settings
If this does not work then a full system reset should be performed on the control panel by pressing the System Reset button. The television will turn off and the green LED light will flash quickly for a minute. When the light stops flashing, the TV will turn on.
If that still doesn't work, then the projection lamp might need replacing and here is how to do that;
Ensure that the bulb is completely cooled and the television is unplugged. Use a Phillips-head screwdriver to remove the lamp compartment cover. Unscrew the lamp cartridge on the rear of the television. As opposed to the cover door, these screws do not actually come out of their chamber and simply loosen the lamp assembly. Remove the old cartridge and insert the new one. Secure the lamp with screws, then replace the cover and screw in tightly.
Please note that, Finger oils can cause the lamp to malfunction.
Projection lamps are powered by mercury. Wash hands thoroughly after replacing the projection bulb.
GOODLUCK
Jul 04, 2010 | Akai PT61DL34 Television
I WAS WATCHIN TV THE OTHER NIGHT AND ALL OF A SUDDEN THE TV TURNED ITSELF OFF AND THE LITTLE GREEN LIGHT IN FRONT STARTED FLASHING VERY FAST -SO I UNPLUGGED MY TV AND THEN PLUGGED IT BACK IN AND THE GREEN...
Some of these sets if you unplug them---The green power light will blink for about 70 seconds before it stops--this is normal as the receiver unit in this set is booting up. Wait for the light to stop blinking and then the set should turn on. Some of these sets develop a problem where the light never stops blinking--usually the receiver is now bad--very expensive to get fixed.
I do this here for free so if this helps you give me a vote here.
SD TECH (San Diego)
Aug 28, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Won't turn on - green light flashing
When this set is first plugged in the LED will flash for 70 to 90 seconds and then stop. During this time the unit will not operate. This is the amount of time it takes for the Digital Module to boot up. If the blinking LED never stops the Digital module is not booting up and must be repaired. I have done quite a few of these repairs and the average repair cost has been between $250 and $300.
May 09, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
HL-p4663w/3 flashing lights
The Problem you have with your set is that your lamp is dead. you will need replace it. The Part number for the lamp is on the side of the TV. BP96-00826A is the part number. You will need a service Person to change the Hour timer in the service Menu.
Jan 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
