Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How does the brake spring on 42" deck go back on?
  • Dwain Pippen May 11, 2010
    Gots to have more info than that, like the model number under the seat.......
  • 513 Answers
Brake spring on the deck to stop the pulleys from turning after disengaging the blades or the actual brake
Posted on Jun 28, 2009
Brake diagram craftsmen 42" mower deck
Go to a parts site and view the diagram. Like Sears Direct
Jul 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where do the springs connect to? On the deck of my Craftsman Lt 2000 riding mower.
main one u need is the one on the engage pulley, it connects to pull plate and the center of the mower deck in the hole in deck. the one foe breaks go to brake bar and belt guid bolt in most cases
Sep 24, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Refer to brake pad arm assembly :I don't understand what keeps the brake pads from always riding on the idler pulleys. the springs keep them against the pulleys.
Hi, the spring on the brake rod pulls the lever forward when the brake is applied and a short lighter gauge spring pulls the lever back. This spring may be missing. Regards Phil.
Aug 22, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I bought a new belt for my2005 lt 1000 42" deck
for a deck no.. Most everything on the deck is done by springs.. what i would do is look at the deck make sure nothing is rubbing the belt making it rip apart.. or make it to not engage.. i would with the engine off engage the blade and disengage the blade make sure all the brakes are pulling away from the pulleys and making sure all the arms are moving to tighten the belt.. if nothing is moving then i double check the cable or however engages the deck (all mowers are different) and if need the part. If the cable is not broken and is still on deck make sure all springs are lubed. If you have any questions please dont hesitate to ask
Jul 16, 2011 | Craftsman Replacement Belt for 42" Deck
I need to how to install spring for the brake lever for blade pulley on deck. I have the end on the lever figure out. The other is the problem.
The brake lever has a hole in it as you must have found the other end attaches to a finger bracket that sticks up from the mow deck.
Oct 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Spring is broken
There are many springs on a riding mower. Is it the clutch spring, the idler pulley spring, or maybe the blade brake springs. There are also springs on the brakes and even under the set. Please be more specific.
Aug 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dont know where to hook springs to brake on mower deck...arm assembly pad brake
Hello Again verlam810:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select the "Mower Deck" Sub File.
>>There are 2 Brackets (#142) that the Springs #147 (Brake Springs) Attach to.
>>We can Use the Breakdown for a Reference if you have More Questions.
>>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
Best Wishes and Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No brakes on craftsman dl 3000 riding mower
Check to make sure brake rod spring is connected,also pads could be bad if older mower,there are two nuts that lock into one another turn in oppisite directions to seperate then adjust back one then tighten other one .
Apr 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
322 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
