Question about Toshiba Satellite P100 Notebook
My computer clock battery nor my ordinary battery will charge ,otherwise computer working fine on ac , could you please help, thanks ,Frank
    Sergeant:
    Champion:
  • 253 Answers
May be your battery is dead so contact your notebook dealer
Posted on Jun 25, 2009
Hi There, I have a HP Pavilion ZE4900 and recently the AC plug in won't work. I have taken the battery out and put it in another comuter that is the exact same and it charges fine, I put my battery in the...
If your computer won't charge the battery, but the battery charges fine in another computer, and you are sure that the charger is good, then your problem is probably the DC power jack. If you wiggle the end of the power cord where it attaches to you laptop, and it starts charging properly, then the DC power jack is broken.
Apr 26, 2010 | HP Pavilion Ze4900 Notebook
No power/charge
Check that the battery is properly installed. Check the AC Adapter for power. Otherwise take the machine back to the seller. It is still under warranty.
Feb 03, 2010 | ASUS Eee PC 1000H Laptop
Batteries will not recharge on Kodak EasyShareDX4330 Camera dock seems to be working fine otherwise.
if your are using the ordinary AA rechargeable battery it will not charge., Camera dock will charge only on a 2 Pack AA battery like KAA2HR batteries or the 2 AA battery that attached together (Ni-MH rechargeable battery pack )
What type of battery are using?
try to purchased KAA2HR
Nov 05, 2009 | Kodak EasyShare DX4330 Digital Camera
Battery empty message when connecting olympus sw 1030 to laptop
Your recharged battery may be weak. May be time to replace.
If the battery power runs out while the camera is connected to a computer or printer, the image data may be lost or damaged. It is recommended that you
use the AC adapter. Do not connect or disconnect the AC adapter while the camera is connected to a computer or printer.Do not remove or load the batteries or connect or disconnect the AC adapter
while the camera is turned on. Doing so could affect the camera’s internal settings or functions.
Sep 02, 2009 | Olympus Stylus 850SW Digital Camera
I have purchased a new battery for my aspire 3620 laptop, the battery came charged and worked fine, the laptop works fine on ac power but does not seem to be charging my battery, the battery is now...
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Jul 03, 2009 | Computers & Internet
Ac adapter will not charge my computer
If the laptop will run from the adaptor, then the adaptor is probably fine. That being the case, if the charge light flashes when the adaptor is plugged in, the battery is faulty. No charge light on an otherwise working system is probably the battery charging circuit in the laptop.
May 17, 2009 | Dell Inspiron 1525 Laptop
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2008 | Computers & Internet
AC /batteries problem with my laptop
Please try to take the battery out then try to power on using the ac adapter only. It is okay to insert the battery this time. Hope this works. Thanks.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Depressing my shutter button on my Fuji FinePix E550 causes it to turn off. When I turn it back on there is a no image message. Is it cheaper to buy a new camera than to have it fixed? Thanks for help
You just need new batteries. That's what the E550 does when the batteries get too low. Please get the latest rechargables. Many of the ordinary AA batteries won't last 50 pictures. Fuji also is rather poor telling you how to charge the rechargables. When the screen goes blue when you take a picture, you must use the camera's de=charging system before recharging--otherwise the rechargables will not take a full charge--that's what's likely happened to you!
Feb 15, 2008 | Fuji FinePix E550 Digital Camera
Compaq V2000 laptop does not power up with AC adapter or battery
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
The controller gets locked up sometimes, you need to clear it out and let it reboot like that....
Dec 10, 2007 | Computers & Internet
Open Questions:
Toshiba Satellite P100 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
