Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I have an old Homelite ez with a Walbro HDA 44 carburetor. Engine is getting to much gas and is flooding out
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 26, 2009
  • Jim Parker
    Jim Parker Jun 29, 2009
    Did this solution solve the problem?
    Jim
SOURCE:
I have an older homelite leaf blower that has not been in use for several years. I put new fuel lines, fuel filter and spark plug on it and clealed resister in muffler. When I try to start it, it will...
The gaskets and the pliable diaphragms in the carb have dried out. Therefore, the carb cannot deliver fuel to the engine. Disassembly and cleaning of the carb will be required (esp. if very old fuel left to dry inside it). After that, a rebuild kit or at the least; a gasket and diaphragm kit will need to be installed. This will then enable fuel to get to the engine. If you repost the exact model number of this machine, I can reply with the part number for a rebuild or gasket and diaphragm kit. Your unit has probably a Zama (will be wrote on the cover with vent-hole) or Walbro carburetor. Kits are available for both.
Sep 03, 2011 | Homelite Garden
Homelite 240, runs but shuts off......... I suspect carburator.....
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. Make sure the carburetor is fastened securely to the engine. If you still have problems, go to: http://www.drystacked.com for a 12 page article on Walbro carburetor theory and troubleshooting. This information applies in a general way to other carburetor brands as well. Hope this helps!
Nov 05, 2010 | Homelite Garden
HOMELITE 330 KEEPS FLOODING
Clean the air cleaner and muffler if plugged. Remove the lower chamber cover of the carburetor and check the diaphragm. It should not be hard, cracked, or have any holes. Also, check the small fuel metering valve that the diaphragm controls for any debris or damage to the needle tip. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors theory and troubleshooting. Hope this helps!
Jun 11, 2010 | Garden
Homelite starts with strarter fluid and then stops
Does the pumper bulb fill with fuel when pumped? I had a similar problem with a Homelite--which turned out to be the location of the carburetor lower-chamber gasket. The diaphragm needs to go to the carburetor body (pin inward), then the gasket and cover plate. Go to:
www.drystacked.com for a 12 page PDF document on Walbro carburetor theory, troubleshooting, and repair. Hope this helps!
Mar 29, 2010 | Homelite ZR10926 16" Chain Saw
There is a half circle-like part which helps the gas to circulate when starting the motor, the plastic thing has a hole from which the gas leaks whenever attempts are made to start the engine. What is this...
Sounds like you are talking about the primer bulb. It is replaceable, Find a shop that can sell you a primer bulb for a Walbro carburetor or take the unit with you and they should be able to match it up.
Good day.
Nov 07, 2009 | Homelite Factory Reconditioned 26cc...
Homelite 42cc, 18" bar chain saw - Engine will not restart after saw has been used for a while. Wait overnight and it starts fine.
After it has been used for a while and it won't restart, try loosing the cap to the gas tank and see if there is pressure escaping. The homelites are notorious for the vent screen in the gas tank cap getting dirty and pressuring up which forces more fuel into the carburetor and floods the motor. This is also aided by spilled mixed gas which has oil in it running down onto the cylinder heads and then the sawdust sticks to it over time and building up where it makes it difficult for the cylinder head to get rid of all the heat it makes from running. This in turn makes the gas tank hotter and makes it build up pressure in the tank. If the vent cap cant get rid of it as fast as it is created the increased pressure forces too much gasoline into the carburetor and it floods it out.
Oct 01, 2009 | Homelite Garden
My homelite tiller stalls after 30-60 seconds of running. i changed plug and checked filter. gas is new
I'm assuming a 2-stroke engine. Does the fuel system have a primer button? Assuming that the answer is yes, the carburetor is not pumping fuel, but starting on the primer charge. Is the carburetor a Walbro brand? If so, got to: http://www.drystacked.com for a 12 page PDF on theory and repair of these carburetors. If the primer works, the main fuel line should be ok.
Sep 17, 2009 | Garden
I have an old Homelite ez with a Walbro HDC 44 carburetor. Engine is getting to much gas and is flooding out
THIS IS CAUSED BY A PIECE OF DIRT STUCK IN AN AIR BLEED JET OF THE CARB OR THE CHOKE BLADE NOT BEING FULLY OPEN, CHECK THE CHOKE BUTTERFLY 1ST, IF IT IS OPEN ALL THE WAY THEN REMOVE AND CLEAN/REBUILD THE CARBURETOR
Jun 25, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
316 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
