Hp 2420 I just installed my fuze kit and now it is making a loud clicking noise...it is printing fantastic but sounds like a gear is getting caught...easy fix or buy earplugs?
    President:
  • 3,085 Answers
The gears that drive the fuser......
RU5-0077, 78, and 79 should be replaced and greased well.
They wear as the fuser main gear wears.
Also put a small shim on the left side guide post of the frame before tightening the fuser mount screws.
Posted on Jun 26, 2009
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
I have an HP laserjet 2420 which has suddenly started making an alarming cracking noise when printing. I have checked the papertrays and nothing seems to be amiss. Any ideas?
> Are you observed this noise while printer initializing?(after switch on the printer)>Remove back cover, check the fuser assm screws, tighten or slacked?>If found any slacked, replace little lengthy screws then existing screws, ensure that don't try to do fully tighten the screws.>Put more pressure to tighten the left down fuser screw.>Replace 20t fuser driving gear.
Dec 13, 2011 | HP LaserJet 2420 Printer
Yesterday while I was printing on my HP Laserjet 4, it started making a loud clicking noise, and jammed. I opened the printer, looked at the gears on the right behind the toner cartridge and I can't see...
The clicking sound usually indicates a broken fixing coupler gear. The is the little gear on the top left side behind the fuser unit in the printer. You can replace it your self to save on a service call. The part number is RF5-0350 and it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_48&products_id=125
Apr 17, 2011 | HP LaserJet 4 plus Printer
HP2420N printer makes a loud grinding sound when printing
This printer had change made to some drive gears. They wear down and cause this noise. If you can find a technician to replace the 3 gears it can be inexpensive. We do it for under $150 with labor and parts.
Apr 15, 2010 | HP LaserJet 2420 Printer
HP P3005 making grinding noises
this is a problem that HP refuses to acknowledges. Its caused by the gear that meshes with the main fuser gear..it wanders to the right as the printer prints. we are checking into a fix for this, since we are getting no cooperation for the manufacturer, Canon or HP. Canon makes the print engine
Apr 01, 2009 | HP Hewlett Packard LaserJet P3005 Printer
Duplex printing in HP 2420dn
I had the same problem. It was due to incorrect properties in the printer settings.
  1. Go to Start >> Printers and Faxes
  2. Right-click on the HP 2420 printer and select Properties.
  3. Go to the Device Settings tab.
  4. Under Installable Options, set Duplex Unit to Installed.
Also, make sure that the Printing Preferences are set to Two Sided Printing:
  2. Right-click on the HP 2420 printer and select Printing Preferences.
  3. Go to the Printing Shortcuts tab.
  4. Select the Two Sided (Duplex) Printing option.
That should do the trick.
HP - please change your setup so that this is set by default!!
Brian Z
Mar 10, 2009 | HP LaserJet 2420 Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Need Directions on how to change a maintenance kit for hp 2420
Hi Bromo381
Here is the link which gives you steps to change the maintenance Kit.
You need to copy the link and open it in Internet explorer and then when the page loads up click on the option that says HP LaserJet 9000 Series Maintenance Kit - Install Guide (multiple language) in the bottom of the page.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&docIndexId=64255&prodTypeId=329290&prodSeriesId=65013&lang=en&cc=us#2
all the very best for you.
Please do reply me back if there is any issues.
Jan 21, 2009 | HP LaserJet 2420 Printer
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
216 people viewed this question
k24674
jasbo
jasbo
