Question about Amana ARGS7650SS Gas Kitchen Range
It has only heated up about 70 degrees in one hour. what is wrong with it?? it is warming up, but wayyyyyyy toooooo slowly!
  • 126 Answers
Remove the oven floor and turn on.look for the orange glow of the ignitor.within 30-60 seconds the burner should fire .if not, ignitor is weak(drawing less than 3.5 amps) and should be replaced.Hope this helps ,please rate my solution :)
Posted on Jun 25, 2009
I must calculate how many kilowatts per hour a 3kw 200 litre geyser will take to heat the water to 70 degrees celsious
go google and type in ---formula for heating water-- it will shows as so many btu or kilojoules to heat 1 liter of water 1 degree in one minute
May 17, 2017 | Heating & Cooling
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Feb 09, 2011 | Heating & Cooling
I've a pentair solar control panel for my solar system for my pool. On one sunny and very warm day in California, the water in the pool remained cold after a few hours of circulation. Therefore, I was...
There are many variables to this......
How big is your pool how big is your solar system.
Solar temps don't rise quickly ever, and definitely not when the temp is only 75 outside.
You need 80-90 degrees or more on the roof to see quicker results, if the water temp is currently at 70 and it's 75 degrees outside and 80 on the roof you will barely get any change.
You will also lose the heat at night due to lower temperatures.
Once it's hotter outside and warmer at night you get the gains and keep them.
Hope this helps
Mar 24, 2017 | Fafco Deluxe Solar Panel Heating System 1...
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Furnace runs constantly since blower motor was replaced
Sounds like they wired it direct to line voltage , it should run through a sequencer or fan relay to cycle on and off , your seq./relay could be stuck closed to but unlikely being it was just repaired , call the service company back before you do anything they are responsible.
Apr 11, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Samsung 8000 btu window air conditioner
Air conditioners rely on a difference in pressure between the "high side" and "low side" in order to perform. Of course, a/c's are designed to work in the heat. Having a cooler outdoor temp of 70 degrees probably is not sufficient to maintain adequate head pressure and will result in reduced cooling capacity. Also, since it was 68 in the morning in the room, it is possible that the indoor coil began to freeze up. Basically, you have a cold coil that you keep warm by moving air over it. If the air doesn't have enough specific heat (what your thermometer measures) it can allow the coil to get colder than 32 degrees and the condensate from all of your humidity will begin to freeze on the coil. My recommendation would be to check the a/c on a day that is 80+ degrees. If you have an avarage indoor temp of 70 degrees you should be able to look for the air coming out to be approximately 20-25 degrees colder than the air being sucked in.
Jun 10, 2008 | Heating & Cooling
Amana ARGS7650SS Gas Kitchen Range Logo
133 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
