Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My keypad does not have a enter button and im trying 2 reset the password....what do i do??
    New Friend:
I had the same problem and I found an old Liftmaster keypad instruction handbook. Check out the picture below and follow what it says. It worked for me!
P.S. Sorry if the picture is hard to see.
P.P.S. To change your 4-digit PIN:
Enter existing PIN, press *, enter new PIN and press *. To test and use, enter your new PIN and press the 0 key.
my keypad does not have a enter button and im - keypad-not-enter-button-im-svzjafdgc43fzm4x4pvaehtn-1-0.jpg
Posted on Nov 12, 2015
  • Ralph Roza
    Ralph Roza Jul 08, 2017
    Worked great. Just changed houses and have a 1994 garage door opener. This solved my problem. Thanks!
  • Marie Gauci
    Marie Gauci Oct 28, 2017
    THANK YOU. Worked like a charm.
    President:
  • 3,197 Answers
You must have a wired keypad. To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jun 25, 2009
How do i change my passcode on a kindle e book reader
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Mar 04, 2015 | Amazon Kindle Dx, Free 3g, 9.7" E Ink...
I didn't realize that was putting a pass word n .How can I open my kindle/
Forgot my password
Mar 02, 2015 | Amazon Kindle Fire HD
I have forgotten my password and have tried kindle support
My daughter forgot hers as well and Kindle support is the only place to get the right support regarding your specific model and directions for resetting your device.
Feb 28, 2015 | Amazon Kindle Touch Screen Wi-fi 3g W/...
I am trying to register my kindle but my password is not being accepted
If it is the Amazon.com account password then go online and change your password. If the device password then try the following:
Forgot my password
Feb 27, 2015 | Amazon Kindle Paperwhite
How to unlock kindle fire
Forgot my password
Feb 25, 2015 | Amazon Kindle Fire HD 8.9"
Password
Complete the following steps to reset the PIN on the 8825 back to 0000.
1. Press MENU.
2. Scroll to System Settings but do not press SELECT.
3. On the keypad, enter *65# (Star, 6, 5, Pound).
4. It will display "System PIN Reset" and return to the idle screen.
Sep 26, 2009 | Siemens Gigaset 8825 Cordless Phone
Keypad is locked
Blackberry has given the keypad unlock code for security purpose if you dont remember your keypad unlock code. You need to enter wrong password for 10 times you're handheld will get wiped out you will lose all the data which is there in you handset, Then it will ask for the Reset password enter the new password and remember that.
Aug 01, 2009 | RIM BlackBerry 8700c Cellular Phone
Htc touch diamiond keypad locked
u can unlock the key lock with long press of call end button like 4 sec see if ti works otherwise
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Mar 17, 2009 | HTC Touch Diamond Smartphone
My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Nov 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad played with by kids
YOU MAY NEED TO REPLACE THE BATTERY IN THE KEYPAD.
FIND THE SQUARE BUTTON NEXT TO WHERE THE WIRES CONNECT TO THE CIRCUIT BOARD. PRESS AND RELEASE THE SQUARE BUTTON - YOU NOW HAVE 20 SECONDS TO ENTER THE NEW CODE AND PRESS ENTER.
HOPE THIS HELPS
Jan 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
6,836 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
