Question about Maxtor One Touch (RBAY080B0USR) Hard Drive
Maxtor I One Touch button
My one touch button is associated with a batch file in "My Documents" to conduct a partition back up. It worked recently, but yesterday didn't. However, when I double clicked on the batch file the back up to my external Maxtor One touch hard drive took place.
SOURCE: Maxtor OneTouch III Mini Edition 80 GB - one touch button not working
Instal cd with maxtor programs on comp.
Posted on Sep 20, 2007
  • 77 Answers
SOURCE: re-partition external HD for windows and mac
Back up all the data on the disk to your Mac. Plug the disk into your Windows computer and format it with a FAT32 filesystem. Both Mac and Windows can use FAT32. Do not format as NTFS.
Posted on Jan 19, 2008
  • 46 Answers
SOURCE: Maxtor drive partition
I'm not sure how you do it with out a program. If you google something like "Partition Editor Program", that may be the best thing for you.
Posted on Jan 26, 2009
  • 121 Answers
SOURCE: Safety Drill using the Maxtor OneTouch 4 Mini
The safety drill ONLY copies documents and email stuff. So the restoration process would only put back all the documents (and pictures) and email info. It should not interfere with the rest of your computer setup at all.
Posted on Jul 15, 2009
SOURCE: maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Posted on Oct 23, 2009
  • 956 Answers
SOURCE: I have been using my Maxtor external drive for about 3
Sorry, Maxtor prog on poota is currupted. Have you recently downloaded programmes? When updating, some progs have a nasty side-effct of hitting some other programmes, not all the time,just your important ones?
You will have to uninstall and reinstall Maxtor prog, Not sure there might be a repair facility, not sure but it worth a try before uninstalling all.
Posted on Nov 14, 2009
0 characters
1 Points
I had my Maxtor One Touch plugged in the USB of my computer this am. It has worked fine up to that point. I have 4 years worth of audio files saved on there.... When I went to unplug my Maxtor this am to...
Return or contact Maxtor. For a fee they have the equipment and processes (that are proprietary) to retrieve your data. Do not restore the HD because it will erase ALL information!
Jul 14, 2011 | Maxtor OneTouch III 500GB 7200RPM USB 2.0...
I was looking for a manual for my Maxtor one touch III - 500 GB - s/n 2cav32oh - I don't know how to remove any files from my Maxtor in order to free up space. Thank you I'm not sure if I received a manual...
Double-click My Computer. Double click on the removable drive. Double click on the name of the backup? Double click on C. Double click on Documents and Settings. Double click on HP-administrator? Double click on Desktop. Keep or delete what you want. Click the Back button. Double click on My Documents. Keep or delete what you want. Hoe I remembered it all ok. Let me know if you need anything else. Nice talking to you Pauline :)
Feb 08, 2010 | Maxtor One Touch III 500GB FireWire/USB2.0...
How do i delete the hp recovery partition on my maxtor one touch. i am trying to use swissknife to change to fat32 and it says it cant because the maxtor contains recovery files. i thought i cleared it...
I guess you wish to reformat the entire drive? OK you must mount the drive with a partition manager, then you must delete all/any partitions. Then reallocate a NEW partition, 0 to the end cylinder number, format the partition and set it to Active. You should be all OK.
The HP recovery is in a "Hidden Partition" so it can't normally be seen, all that HP does to "Restore" stuff is to mark that partition as active on boot up and the software runs when it boots to that partition.
The only way to rid it is to completely "Flatten" the drive, IE: Removal of every and all partitions and reallocate space to a new one.
Jan 27, 2010 | Hard Drives
I want to backup my computers (4) and have maxtor partitioned and used at purchase time, but now when I connect it I get no prompts or choice of hard drive to back up. How do I go about back up?
You have a varity of option to do your backup depending on the type of backup you want to do.
1 Documents and folders
To backup your document and folders you can just copy the Documents and folders to the external drive.
You could also use the backuo feature of the Operating system you have like windows backup to backup your documents and folders.
2 System backup of your system.
You can not use a copy accross to do the complete backup of your system. You can use the windows backup to do this or a third party backup software.
Windows Back for Windows 7.
Click on Start ----- Controll Panel ----- System and Security ------- Set up Backup ------ Select where you want to save your backup ( the external Drive you connected to your system) in the box ------ Next ----- Choose the files or drive you want to backup and click next ------- Review your backup settings and save settings and run back.
This will save your files to the external drive you added to your system.
Jan 08, 2010 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Maxtor only backing up certain files instead of entire computer.
Your system is backiing up only the changes or deltas from the last backup. If you truly want to backkup everything again, you must opent the one touch backup utility and set the full backup option. You can find the one touch program under the Progams list on the Start menu.
Oct 14, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Maxtor mini one touch 4
When you were in device manager did you notice if it was enabled? Did you try to force install the hardware somewhere else, or did you try to change what driver was used?
Ryan Frame
Creative Energy Associates Technical Center
Aug 24, 2009 | Seagate 80GB One Touch 4 Mini-maxtor USB...
Jul 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor one touch
Hi, You can try and use PowerQuest PartitionMagic. It will allow you to partition/format/check most HDs including USB connected. Choices/options are from FAT16 to NTFS and Linux. Another handy disk utility that is a freeware is HP's bootable flash utility at Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 10, 2007 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor One Touch (RBAY080B0USR) Hard Drive Logo
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
