Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I have a clunking in my foot pegs 06 streetbob
I have a clunking in my foot pegs when letting off the power and wen brakeing just had new swinging arm berring and engine aligned allso cheked for warped disk just had the front mount off seems ok im out of ideas. 06 street bob
  • vinny_m793 Jun 26, 2009
    yes mate this is something i will look at is it the chain or the compensater nut
  • 27 Answers
Check your primary chain. Don't know if it is, my 07 used to do the same - feels like something hitting more on the left side.
Posted on Jun 25, 2009
Why does 2001 Toyota Avalon dash light for brakes stay on.?
Remove the brake fluid cap which contains the sensor and shake it ,a good arm swing and if its sticking then this will free it it up
Jul 07, 2014 | 2001 Toyota Avalon
I have a ninja 250r and came of the other day. The black bit of the frame that holds the exhaust and passenger peg up snapped do u know what it is called and were I can get one
The part is welded to the swing arm. A new swing arm is $228. Take the bike to a local commercial welding shop and they can easily create a new mount then weld it in place.
Jun 25, 2011 | 2006 kawasaki ZZR 250
I have a 75 flh with the passenger peg mounted to the primary inspection cover.is this stock. if not where do they mount
Yes, this is where the passenger foot peg on the left side of the bike goes. There is an arm that clamps onto the round stub on the inspection cover and is afjustable to almost any angle. The right side foot peg support bolts to the end of the transmission and also has an adfustable arm that clamps onto a stub on it. Then the pegs go on the end of the arms. Go to this site and take a look . http://www.bikebandit.com/1975-harley-davidson-flh-1200/o/m770#sch171752 I'm pretty sure they didn't move the peg brackets to the seat tubes of the frame until 1977. If your bike has two holes in a welded-on tab on the rear of the down tubes behind the primary and the transmission, you can use the later model peg brackets. But, if your bike has no holes in the frame or the swingarm for passenger peg brackets, this is the only style you can use and stay original. You could fabricate and weld on tabs to later model peg brackets or use clamp on brackets and pegs.
Good Luck
Steve
Apr 03, 2011 | Harley Davidson FLHTCUI Electra Glide...
How do you remove the brake pedal from a 1994 sportser.
To get the pedal off, you must take the front belt pulley cover off. There is a nut on the backside of the foot peg with a cotter key in it.
Remove the master cylinder and swing it out of the way, Be careful and don't bend the brake tube. You may be better off taking the tube loose and bleeding the brakes once you're finished. Remove the three screws and the large nut holding the cover on. With this cover off, you have access to the nut on the back of the foot peg.
Good Luck
Steve
Aug 18, 2010 | Harley Davidson XLH 1000 Sportster...
How can I diagnose a clunking noise in the front end of my car? It's a 13-year-old Lexus GS400. Sometimes there's a light clunk associated with braking. Other times there's a similar clunk when rolling at...
Definitely have the front end and brakes checked out at a place like Sears where the diagnostic is a no charge deal.
They may be able to detect what parts are obviously loose while it's on a lift.
I would not let this go very long.
The price might be high to fix this on a Lexus compared to a Chevy, but I think that it's worth investigating.
Where did you have the control arm bushings replaced?
Jul 12, 2010 | 1998 Lexus Gs 400
Fix belt on 1200 sportster 0
I assume you want to know how to replace a final drive belt on a Sporty. First off, be glad you ain't working on a Big Twin. Sportster's are much easier than Big Twins to replace the belt on.
First, get the bike off the ground where you can remove the rear wheel. Then, remove the rear shock on the right side. Remove the bolts from the rear master cylinder and the large nut that holds the right foot peg on. Remove the front pulley cover.
Take the new belt and install it with the right leg of the swing arm through the belt. You may can work the belt over the front drive pulley. If not, use an air wrench to remove the pulley and install the belt. Retorque the pulley to 110-120 foot pounds. Remember the threads on this nut are left handed.
Reinstall the rear wheel and shock absorber. Adjust the belt to the proper tension. Then replace the front pulley cover and rear master cylinder.
Check the rear brakes for proper operation.
Good Luck
Steve
Jun 14, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
The brake lights on my 06 kia sedona will not turn off
Look above your brake pedal and you will see your brake switch up along your brake pedal arm. It will either be between the brake arm and the firewall so when you brake it pushes the switch in. Or it will be between the dash and the brake arm so when you brake it pulls the switch out. Most likely this switch needs to be replaced
Oct 20, 2009 | 2002 Kia Sedona
I need a price for Front forks
You might be best servered by taking your list to your local HD dealer, or calling say a Dennis Kirk, ot J&P Cycles. As they can give you best prices on the package for the parts you need.
Oct 06, 2009 | 2001 Harley Davidson FXST Softail Standard
How do I remove the rear brake calipers on a 05 victory hammer motorcycle. I dont see any bolt heads at all.
On my 06 kingpin, there is a single pin that is held in place with a retaining pin. Take out retaining pin, slide out long pin, then pads slide right out. Be sure to press calipers open with screwdriver prior to removing old pads and be careful to not scratch the rotors
Jul 09, 2009 | 2005 Victory Hammer
Lands Phones Logo
146 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
