Question about Motorola Mobility SLVR L7 Cellular Phone
Have a t-mobile phone but i have att sim card..how do i unlock the phone? its a samsung SGH-T519 phone. want to use the phone but when i put my sim card in it, it says wrong card or emergency calls only. this is my boyfriends old phone, and my current cellphone three att has water damage..i need a phone that works, and his is the only one i can find to use
SGH A817 to t-mobile
Yes, on an unlocked phone you can easily switch SIM cards. All you can do is put the T-Mobile SIM card in the phone and it should show signal bars on the top of the phone. If not you can call up T-Mobile and ask them for correct network settings and they should be able to help you out with this.
If the phone is not unlocked it wont work with any other sim card except the original carrier SIM card. In this case you first need to unlock it.
I am posting the link below incase you need unlock code for your device:
Unlock Samsung Solstice 2 SGH-A817
Apr 15, 2013 | Samsung SGH-A817 Solstice II for ATT...
I NEED TO UNLOCK AN ATT SAMSUNG SGH-A137 PHONE
Its possible by codes.Get the unlocking code for your mobile from http://www.simpleunlocking.com/ .It helps to unlock your mobile easily.
May 18, 2012 | Samsung SGH-A137 Cell Phone
I have a samsung SGH/A927 need to unlock to use a differnt sim card with a differnt att to net 10
Yes..you can unlock your Samsung SGH-A927 using the codes.I found an unlocking service at Prounlocking.com .They offer the service at cheap price.Through this you can unlock your mobile easily.
Nov 18, 2011 | Samsung SGH Cell Phones
How do I unfreeze my att samsung eternity without a computer cord
Computer card Unlocking is very Big process,So that You can use the Unlock code....also in computer card Unlocking you need to use Cable,Software,USB port,Boxes etc,so take big time ,it's risk process,cost High also,So that i would suggest the Unlock code the simple method to Unlock Your Samsung SGH-A707 SYNC phone,You need to Unfreeze means specify the Network ,Country it locked now?
You can get the Unfreeze Code at
Simpleunlocking and Unfreeze the Phone from Lock...
Samsung SGH-A707 SYNC Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung SGH-A707 SYNC mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-A707 SYNC mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-A707 SYNC with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-A707 SYNC is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-A707 SYNC.
Each Samsung SGH-A707 SYNC mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-A707 SYNC mobile phone using the form above.
Jul 18, 2011 | Samsung SYNC SGH-A707 Cellular Phone
I was given a Samsung phone. Model: SGH-A437 an ATT carrier. with ATT Sim card in it. Phone is shut off. I tried to put a T-moble Sim card in it, but doesn't work. the screen say's wrong card. how...
Hi you can contact your provider to get unlock code for your mobile or can try from online provider..you can try superunlockcodes to get unlock code for your mobile and get it unlocked..
Jun 12, 2011 | Cell Phones
Need puk2 for my samsung sgh-t519 from t-mobile
call your carrier from a land phone, the rep will walk you through...and give you the 16 digits to get your cell unlock
May 29, 2010 | Samsung SGH-T519 Cellular Phone
I purchased a sim card from tmobile to replace my att simcard on my samsung SGH-A707.The new sim card won't work,it sy's incorrect sim and networt lock.
Hello
The sim wont work because it is locked to the att network which means it will only work with att sim cards.
You will have to unlock the phone from the att network before it can work with the T mobile sim card
You should contact your network provider so as to get steps to unlocking your phone from the att network or you should contact a repairer to help you unlock it
Thank you for visiting fixya
Mar 10, 2010 | Samsung SYNC SGH-A707 Cellular Phone
I need a code to unlock my SGH-D415 t-mobile cellphone
HI HERE IS A SOLUTION CAREFULLY FOLLOW IT Warning: Do not enter any wrong unlock unlock codes on your Samsung SGH-D415 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Samsung SGH-D415 mobile phone with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-D415 mobile phone is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-D415 mobile phone.
If it does not work, you can try these methods:
Method 1:
2 - ;;Phone;; will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-D415 mobile phone shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-D415 mobile phone.
3 - Compose : #0111*CODE#.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-D415 mobile phone.
Each Samsung SGH-D415 mobile phone has an unique unlock code. You can buy the unique unlock code for your Samsung SGH-D415 mobile phone at www.mobileunlocksolutions.com. HOPE YOU SUCCESSFULLY DO.... PLEASE RATE ME THANK YOU
Feb 19, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Samsung SGH T519
Call World of Wireless in St.Paul Mn, #651-379-5555 They unlock any cell phone to be used with any service provider and it cost as much as $20.00 see what they can do for you they have unlocked many of my phones. bmauri67@live.com
Apr 16, 2008 | Samsung SGH-T519 Cellular Phone
Samsung sgh-x426
I also have a x426 from 2003 and it wont work with the new ATT sim cards either, This is because of the Cingular/ATT merger which created a new network. The older original ATT phone must be unlocked to use a sim card from the new merged network. Try calling ATT Mobility customer service and request the subsidy unlock code. They are required to give it to you upon request, but it takes several days usually to get the code. I know because I used to work at a ATT call center.
Dec 23, 2007 | Samsung SGH-x426
Motorola Mobility SLVR L7 Cellular Phone Logo
91 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
