Question about Nokia N95 Cellular Phone
Nokia Lock Code
I changed my nokia lock code when i was drunk lol and can't remember what i changed it to, though it was my date of birth but doesn't seem to work. Can anyone help me with this?
  • 97 Answers
SOURCE: how to unlock a Nokia 6630?
Give this a try?
http://www.symbian-freeware.com/download-unlockme-1-0.html
Posted on Nov 29, 2007
mrdeepak
SOURCE: Nokia N70 code
Unlock Security Code using Memory Card
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code.
Code: http://www.MegaShare.com/218723
pass: theologaster
Posted on May 24, 2008
SOURCE: I have just reset my Nokia E71, but my lock code
dial 112,call then cancel it.simple but u must do it every time u off ur phone.
Posted on Jul 19, 2009
niraj_gharat
  • 151 Answers
SOURCE: i forgot my nokia N79 lock code, someone please help.
pls go to service center if in warrenty...or reinstall the software of phone from nokia.com
Posted on Aug 07, 2009
ylit
  • 107 Answers
SOURCE: i dont remember my nokia 6681 phone lock code.
here is your master code 3037526143 just put it when it as.just pm if it didnt work
Posted on Apr 13, 2010
I forget my nokia5253 code plz what can i do unlock code
HI PZL TRY THE FOLLOWING THERE ARE THE LIST OF NOKIA
SECRET CODES .. >>
*#7780# Restores Factory
Settings (Memory, language,
counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the
SIM clock can be stopped. SIM
clock stop is a kind of stand-by
mode which will save battery
time. This code doesn't work
with software version 4.59. Nokia 3110 Secret Codes
*#3110# : Checking the
phone's software (SW) - Also
called "Firmware Revision
Information".
Nokia 3110 Secret Codes *#92702689# [*#war0anty#]
Press the following warranty
code
7332 (OK) : Displays the date
of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial
Number
7832 (OK) : Displays (if found)
the date where the phone was
purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the
Purchasing Date MMYY
(Warning : You can only set
this once.)
Nokia 3110 Secret Codes 87267 (OK) : Transfers ALL
phone numbers, pictures,
sounds from one phone to
another
6232 (OK) : Displays the Month and Year of Manufacture
(0997)
This code is able to check,
activate or remove SIM card
restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 -
depending of what lock you
what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for
Country-Lock status
#pw+1234567890+2# for
Network-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit
code, based on the phones
IMEI number.
[ No requests for the "Master
Code" will be entertained. ]
Nokia 3110 Secret Codes Eg. To remove restriction on
Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your
phone use 10 random
numbers Eg. 1234567890 as the (master code)
eg. To check if phone if
restricted on lock 1 type the
following code:
#pw+1234567890+1# 1: Insert sim card of different
provider.
2: Turn on the phone and press
the UP VOLUME key for 3 sec.
then release it and the phone
says PIN CODE? 3: Press the "C" key
4: Then Press * and wait until
it disappears and appears
again, then press * one more
time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or
ACCEPTED) and the SIM card is
accepted until you restart the
phone again. NOTE: On version
5.04 Nokia has removed this
option. Fast silent mode
*#06# : Checking the IMEI
(International Mobile
Equipment Identity)
Sep 09, 2016 | Cell Phones
I change the lock code of my nokia N70. I can't
I you have a Nokia n 70 compitable usb cable just follow this How to Generate Your Phone Security code..Only for Nokia bb5 .Just download and extract on your desktop after that connect your phone via usb .thanks for visiting fixya
May 08, 2012 | Nokia Cell Phones
I forgot my lock code on 6020 nokia phone how can i remember that lock code?
You have to reset your mobile if you forget your security lock.I found a free master reset service at Unlocking4free.com .Through this you can reset your Nokia 6020 easily..
Dec 27, 2011 | Nokia 6020 Cellular Phone
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
Forgotten lock code
Call the cellphone company and ask them to give you the lock code or you can search for ways on Yahoo.com
Dec 10, 2009 | Nokia 6300 Cellular Phone
Ulnlocking code for Nokia N70
I have a noikia n70 phone, i change the securitylock code and could not remember the code
Jul 07, 2008 | Nokia N70 Cellular Phone
Nokia N70 code
Have you set a code to protect your phone, or have you set the PIN of your SIM card?
To reset the PIN, you need the PUK (Personal Unblocking Key) for your SIM card. Some service providers provide the PUK with your SIM card. In any case you should be able to get the PUK from Airtel.
May 26, 2008 | Nokia N73 Cellular Phone
Locked out
to over the lock the eprom needs to be taken out and resolder back that will reset the parental lock when ever you put in a code use a eamily member birth date yours or a friend birth date or a house address
Mar 04, 2007 | Panasonic PV-C1353W 13 in. TV/VCR Combo
Nokia N95 Cellular Phone Logo
69 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
