Home | Canon | imageRUNNER C3200 Copier | E020 0081 I CLEAN THE...
Canon imageRUNNER C3200 Copier
Problem for Canon imageRUNNER C3200 Copier
E020 0081 I CLEAN THE MACHINE AND CONTINUE THIS
By grupola58951 on Jun 25, 2009
E020 0081 I CLEAN THE MACHINE AND CONTINUE THIS ERROR AND THE DRUM TU RUN 62000 COPIES IN CANON IRC 3100
Solution #1
posted on Jul 05, 2009
Not Rated)
redzventures
Rank: Guru  Canon Expert
Rating: 91%, 51 votes
Okay, saying the patch sensor is not enough, if the guy new where it was he would clean it. To clean the patch sensor, remove the drum unit and look inside the machine and up to see a white strip running from the front to the back of the machine. The patch sensore is located along this strip and should be cleaned with a lint free cloth.
Was this helpful?
Yes
No
Solution #2
posted on Jun 25, 2009
Not Rated)
mrfixit3441
Rank: Master
Rating: 88%, 2 votes
The patch reader that reads the drum is either fault or you need a new drum
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER C3200 Copier
Questions and Unsolved Problems for Canon imageRUNNER C3200 Copier
Do you recommend Canon imageRUNNER C3200 Copier?
Answer
Answer
Hi there, As a graphic designer I'm looking for the best possible/high quality printing using... (More)
Answer
my imagerunner 3035 says load paper when it is full
Answer
need to install printer to the router with ip network configuration
Answer
How do I reset pass word for our 400S copier?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageRUNNER C3200 Copier:
Top Copier Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
