Question about Refrigerators
How to install door gasket for subzero freezer model 3211
I have purchased a gasket for my subzero freezer door and would like some instructions on how best (and easiest) to install it.
I think you just unscrew and take off the metal trim on the door and then replace it. I have a similar issue where did you find the gasket for sale. If you dont mind could you email me at maclaren at tulane dot edu with that info. Thanks, James
Posted on Jul 26, 2009
When was the subzero 632 made?
Are you asking when was the first one made, they were in production for several years you can use the serial number to tell the date of manufacture
Sep 05, 2014 | APW Wyott SubZero Refrigerator Freezer...
Subzero 611s freezer door will not open
It sounds like something has fallen to cause or it is badly frozen inside
Aug 17, 2014 | APW Wyott SubZero Refrigerator Freezer...
I need a track for a subzero freezer storage tray
Find the model # and log onto sears .com look for parts.com enter your model# order it from there..
Oct 29, 2013 | APW Wyott SubZero Refrigerator Freezer...
Clogged up icemaker on subzero 601F due to the door not being properly shut. Do I need to defrost the whole freezer to unclog or is there any other way?
You can buy a little steamer at the store and use it to defrost small areas. usually it's the fill tube that freezes, and you can hit just it with the handheld steamer. Lots of times however, this model will create a large ice flow below the glass shelf behind the upper basket and icemaker. this is usually caused by a bad drain trough heater. the only way to defrost this is to turn the unit off for 2 days and put towels down inside it and underneath it to catch the water as the ice melts.
Sep 16, 2013 | APW Wyott SubZero Refrigerator Freezer...
I replaced the water filter on my Subzero BI48SD and now the water dispenser does not work. Any suggestions?
After Replacing Filter, Press Filter Reset Button behind the Unit Grille for 5 Seconds to Reset Counters
Aug 12, 2013 | APW Wyott SubZero Refrigerator Freezer...
Freezer door pops open on Whirlpool Model WB FNGF V000
Good day,
If the gasket on the freezer door mates properly to the cabinet, and the door pops open when the main door is closed, then it means the magnets embedded in the freezer door gasket, have become weak.
One thing you can do, is elevate the front of the machine slightly, and place items of weight in the door itself.
Failing that solution then.......
You will need to replace the gasket.
It should be available at most appliance parts houses.
Ask the counterman for instructions on installing. If he's good he will give you explicit instructions on how to replace the gasket.
Follow those instructions, because if the procedure isn't followed, the door may become warped, and will not fit properly.
Dec 14, 2009 | Refrigerators
SubZero Model 532 (1994) Refigerator/Freezer:
My SubZero 550 Regrigerator/freezer is not making icecubes. Any ideas
May 12, 2009 | Refrigerators
I have a subzero frig, 601R, after puuting in a new gasket around the door, it doesnt close all the way. The gasket looks perfect. Is there an adjustment on the door hinges? thanks
Congratulations on being able to install one of these beasts. You may have a gasket dragging on the hinge side of the door. Apply some petroleum jelly to this side of the gasket so that it doesn't hang up on the ref cavity. Make sure that all your screws are screwed all the way in. There are no adjustments. Use a blow dryer to heat gasket to get any wrinkles out. careful not to scorch the gasket.
Mar 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
930 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
