Question about Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000
6750 coleman generator running fine but no output,have revved the motor but doesnt help
  • 1 more comment
  • gvcvlc Jun 25, 2009
    this generator has very few hours on it,maybe 5 tanks of gas,still the brushes?This happend once before and revving engine fixed it
    thanks
    gary
    I dont know yet
    brushes look brand new,also this is a 6750 and looks nothing like the diagrams for changing brushes.This model has a built in exciter and supposedly we are not to energize it,Any ideas?
    Thanks
  • 952 Answers
I've had the same exact problem with my genset. the culprit is worn out brush... go to this link for step by step instructions on how to change your genset brushes.
http://www.alpharubicon.com/altenergy/colemanpenwu.htm
I hope this helps.. save the link for future reference. you will need it after some time. the brushes are disposable.
Posted on Jun 25, 2009
  • Jac Lawrence Pimentel
    Jac Lawrence Pimentel Jun 25, 2009
    Even if your genset is new, please check the brushes to make sure its okay.
My coleman powermate pro 6750 generator only puts out like half power, after 30 minutes it loads up and runs fine. what causes this?
It would be surprising to me if the engine was running at proper speed while it is not putting out full power. I am not familiar with your particular model so my answers are coming from knowledge of generators in general. If it is running at proper speed then it would have to be a regulator problem. This is assuming that it isn't trying to run in an overload condition and that you are letting it run a little before you put a load on it.
Dec 22, 2015 | Coleman Electrical Supplies
Have a coleman powermate 6750 generator that has quit producing power.
If the engine is running with the alternator not outputting then you must check with the LOAD TRIP switch.
if not remove the load and check if there is output. If not there is fault in tha alternator which might need some consensus.
Nov 05, 2011 | Coleman Powermate Powermate 5000W...
Problem with the Coleman Power Generators I have a Coleman Vantage 3500 motor runs no generator output what if it doesn't have brushes?
My owners manual says to take it to a service center to get the generator "excited" if it has no brushes. Hope this helps
Jan 19, 2011 | Coleman Electrical Supplies
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
No output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Coleman Electrical Supplies
This sound like a loss of residual magnetism in the generator. The field will need to be "flashed".This is also known as re-exciting the field of the generator.
The Coleman manual gives these steps:
1Use a 6 Volt lantern batters (dry cell) or a 12 Volt automotive battery.
2.Disconnect all loads from generator.
3. Remove the brush cover (that's the rectangular plastic cover on the end of the generator.)
4. Plug a lamp or light into the generator before starting the engine. The light will illuminlate when ?Voltage has returned.
5. Start the engine with no load connected to the generator.
6. Attach the "-" lead of the battery to the negative brush. Very briefly touch the "+" lead of the battery to the positive brush. Remove as soon as Voltage builds up.
Sep 02, 2009 | Coleman Electrical Supplies
Engine won't maintain constant rpm
Hello There
Try cleaning or replacing the spark olug.
Hope this helps.
Many Thanks
May 22, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 5000 generater-no AC output
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Jan 09, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000 Logo
200 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
