I was transporting my tv to another location and the wind destroyed the linticular and the fresnel was pushed in. Where can I find a replacement linticular screen and how do I reinstall.
  • 41 Answers
Try here. They might have the part and service manual. http://www.encompassparts.com/shop_guest.asp
Posted on Jun 25, 2009
How to transport a 56 inch general electric projector tv
I transport them all the time and the best way to do it is to put something down soft in the bed of a truck then lay it down screen first on its face. If you stand it up in the bed of a truck the wind usually destroys the screen. laying them down face first doesnt harm them as long as you have somehing soft to lay it on so the screen doesnt get scratched.
Feb 12, 2013 | GE D52GW12 52" Rear Projection HDTV-Ready...
Find generic dlp lenticular screen and fresnel screen
I would find out the make of the lens, probably cannon. The Fresnel and Lenticular screens are nothing to do with the size of the picture, the lens does that bit.
Oct 01, 2017 | Televison & Video
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
I need a part
Go to www.encompassparts.com and use the guest login. Enter part number 246459. This looks to be a screen assy which is both screens. That is the way RCA always sold there screens. I don't know where to get just the one screen unless you call around to different shops and try to find a used one. Thanks
May 16, 2009 | RCA P61939 61" Rear Projection Television
Screen cracked and dirty
There are two screens on PTVs. The one on the outside has vertical lines in it and it is called the linticular screen. The one on the inside has circles in it and it is called the fresnel screen. You did not state what make or model number this is, but these screens can be very expensive ~$300. You may be able to locate one if your set is not too old. Let me know if this helps or if you need more info. With the model number and make I may be able to locate one for you.
Apr 29, 2009 | Hitachi 50UX57B 50" Rear Projection...
I have a Magnovox HD TV Progressive Scan (Floor Model) TV
You can find a replacement Philips/Magnavox fresnel screen, in stock, for this model (51MP392H/17) at this following link from a major parts distributor:
Philips / Magnavox 51MP392H Replacement Part Fresnel Screen
And here's a link for the Lenticular (middle) Screen, if needed:
Philips / Magnavox 51MP392H Replacement Part Lenticular Screen
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Nov 08, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
Trying to find part
Well normaly there are two the one in front is the linticular # BP67-00164A the next screen in is the fresnel # BP67-00165A and in some cases there is a protective screen which is simply a piece of plexiglass, but since these screen srun about $275.00 Each I hope that both were not damaged, Prices and screens at www.vancebaldwin.com
Feb 19, 2008 | Samsung HL-S6187W 61 in. HDTV
Mitsubishi ws-55517
the outside screen is called a linticular lens and the inside one is the fresnele lens. They both should come out together from the front as the trim on this set if im not mistaking pulls or slides off then theres mounting plates holding it on. Becarefull and dont try to clean the mirror as the coatings on the outside of the mirror. Also be very carefull not to touch any componets as theres extremly hi voltage in these sets even with them unplugged. Good Luck
Jun 14, 2006 | Mitsubishi WS-55807 TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
