Question about Canon MF3110 All-In-One Laser Printer
How to dismantle Canon MF3110 to clean inside?
My Canon MF3110 (multifunction laser printer) had a paper jam that I only discoverd and cleared a few days later. Now, the print quality is really bad. There are now large areas of black smudges all over the paper. I suspect there are old toner powder sticking to the roller/drum due to the paper jam. However, I haven't figured out how to dismantle the machine to get inside to clean. Can anyone offer some tips? Any help will be greatly appreciated.
  • 5 more comments
  • koronno Nov 25, 2007
    I have the same problem. It prints really dirty with black ink all over the pages.
  • Anonymous Jan 27, 2008
    Just the same problem. I guess no one has a solution?
  • Anonymous Mar 05, 2008
    Same problem, however I don't remember a paper jam kicking it off
  • Anonymous Jun 06, 2008
    I have a similiar problem but minor in nature. The print comes out with a gray line to the right end side of the page. I suppect residue toner on the fuser but Canon does not seem to provide any manual on how to fix the problem.
    Can anyone help.
  • icch Nov 11, 2008
    The paper breaks and not reachable no way to take the jammed paper out I cannot pull the paper
  • Anonymous Feb 25, 2009
    pulled paper out of the back because it was jammed. I remember the manual said not to do this but I had no other option. The print quality sucks since then. Any suggestions on how to get this fixed?
  • Deblegs46 May 25, 2009
    We had a paper jam the other day and the only way that we could get the paper out was to gently pull it out. There was no other way of getting the paper out. Since then the printing has gone wrong and all we have been getting is black ink all over the page.
The service manual can be found by googling for "Canon MF3110 service manual" - however since it's not located on the Canon page I am not sure if the download is legal.
Posted on Jul 06, 2008
Buy a new printer.
Posted on Mar 16, 2008
Paper jam message appears in initial setup of new printer and won't clear
If no paper used or jammed, next thing see that menu says , to help clear your problem.
Mar 16, 2015 | Canon MF6160DW - MFP - LASER PRINTER -...
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Canon mf3110 multifunction will only print one sheet of paper and then says check paper size
installing latest driver & toolbox from Canon USA solves problem. DO NOT USE 3rd party a virus.
Dec 12, 2012 | Canon ImageClass MF3110 All-In-One Printer
My printer not working in windows 7 please tell me
I have luckily managed to figure out how to get my Canon MF3110 printing with Windows 7 64 bit even though there is no driver for Windows 7 64bit for the Canon MF3110 Multifunction Printer. The solution is to download the Windows 7 64 bit printer drivers for the Canon MF5750 and then install the drivers as your LPT1: Printer. Note this same work around should work in theory with the Canon MF3111 model as well.
You know you have the right file because if you go to Canon's website link here:
Select Windows 7 (x64) in the drop down
And download these drivers:
Jul 17, 2011 | Canon MF3110 All-In-One Laser Printer
There is a message called "Paper Jam". What can i do for this?
Look in your printer manual. It will tell you how to pull the paper out. If you can't see it in the front you can probably open it in the back somehow.
May 12, 2010 | Canon MF3110 All-In-One Laser Printer
Canon mp830, when turn on error code 6A00. When lift lid, no lights on ink cartridges, ink cartridges do not slide into middle for access. When turn machine on, hear funny noises as heads try to clean...
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 25, 2009 | Canon MF3240 imageCLASS Laser...
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Paper jam
try removing the back door where you are supposed to clear a paper jam from, and then replace it. If that does not work try leaving the printer unplugug for a few minutes. If this does not work, try printing a document with the printer, and see if it clears the error then.
Jan 10, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Canon MF3110 All-In-One Laser Printer Logo
914 people viewed this question
old marine
old marine
