Question about Toshiba 55H70 55" Rear Projection Television
Can't adjust the value of the width in Service mode ' WID '
Do anyone know how to fix the width of the Toshiba Model TN50V71 . The picture of which can not be adjust in the service mode i.e in the 'WID' I tried to tune it from the lowerest to highest value but no matter what value you enter, it does not respond and the picture at both side is deflected inward and I also noticed a red and blue separate verticle curve lines.
Can anyone help please.
    President:
  • 4,402 Answers
Http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
I have a Sylvania 6427 17
It sounds that the width of the picture to your TV is more than normal. There are two reasons for this fault. If the width adjustment data value in its service menu mode has been misaligned or the output DC voltage from the main power regulator is more than normal. You can determine which among the condition stated above is now effected to your TV
Just look at the picture. If the width and height of the picture is seem to be more than normal, make sure that the power regualtor section circuit has the fault. If the dimension of the picture is affected to its width only, [excess than normal] the data value with service mode should be checked.
Also note the position of the picture. If the picture position has moved so much than normal, ether towards left in this case, you have to adjust the picture position. Anyway, it will be best to contact any experienced service technician, since, service mode entry and data adjustment are skilled work.
Jul 31, 2012 | Sylvania 6427GG 27" TV
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    I recently picked up a Toshiba TN50V71 & am not sure where to start in troubleshooting it. There is no picture, & the led power light is steadily red.
    Rear projection TV is made up of a TV, optical lens and a screen. So picture projection problems are from the small TV tube. Take off the back to reveal the TV and see what could be replaced?
    Aug 16, 2010 | Toshiba TN50V71 50" Rear Projection...
    Red Hue
    Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
    Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
    Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
    Picture image does not look full when showing people
    There is a service menu adjustment. I have seen several of these sets with bad components in the horizontal width control circuit. maybe your other set has a width problem. put both on the same channel. like cnn with the ticker on the bottom. what is the difference in size?
    the width adj. procedure is: with the set off. use the remote, enter. MENU>5>VOL+>POWER . the set will come on in the service mode. then with the menu adj. buttons you can step threw the service menu to H.WIDTH adj. until full picture. also VERT. HEIGHT. when you are done adjusting make sure you press the mute button and watch the word WRITE flash from green to red or you won't save your adjustments.
    Jan 07, 2010 | Sony FD Trinitron WEGA KD-27FS170 TV
    TV one side slight blurr
    hello, here some help with this
    hope this help below are adjustments
    and values
    How to enter into Service Mode
    While pressing [VOLUME ( - )] button of the main unit, press [RECALL] button of the remote control three times within 2
    seconds.
    10.1.1. Key command
    "1" button...Main items Selection in forward direction
    "2" button...Main items Selection in reverse direction
    "3" button...Sub items Selection in forward direction
    "4" button...Sub items Selection in reverse direction
    "VOL" button...Value of sub items change in forward direction ( + ), in reverse direction
    Value is shown as a hexadecimal number.
     ·Preset value differs depending on models.
     ·After entering the adjustment mode, take note of the value in each item before starting adjustment.
    Main item Sub item Sample Data Remark
    ADJUST CONTRAST 000
    COLOR 3F
    TINT 03
    SUB-BRT 800
    WB-ADJ R-CUT 80
    G-CUT 80
    B-CUT 80
    R-DRV E6
    G-DRV F0
    B-DRV FC
    ALL-CUT 80
    ALL-DRV FC
    OPTION BOOT ROM Factory Preset
    STBY-SET 00
    Emergency OFF
    CLK MODE 00
    CLOCK 000
    AGING RGBW
    COUNT
    ALL WHITE
    ALL RED
    ALL GREEN
    ALL BLUE
    ON/OFF
    RAMP WHITE
    RAMP RED
    RAMP GREEN
    RAMP BLUE
    1% WINDOW
    COLOR BAR
    A-ZONE B-ZONE/4 TRIO
    SCROLL
    WHITE FLAME
    RM-SET CODE A Fixed
    SRV-TOOL - See next
    10.1.3. How to exit
    Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control
    good luck hope tis help.
    Jan 18, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
    Adjust Picture on Rca Projection TV
    check the horizontal frequency and the electrolytic filters used in it. damm sure there must be filter that make it look like a concave. also check it by decreasing the width from the service mannual of processor. there is a service switch for every processor. that is his internal control unit. may be it is from the processor adjustment. you can set it by increasing or decreasing the frequency or display width-height clock pulse from the processor. to know about that perticular switch you must concern to the company....
    Feb 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Toshiba TN50V71
    http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
    Nov 10, 2007 | Toshiba TN50V71 50" Rear Projection...
    Default service menu codes
    They are all different, in every set. Why do peeps not remember to leave these settings alone! sorry but now you will need to have the set serviced.
    Jul 11, 2007 | Toshiba 27AF41 27" TV
    Toshiba 55H70 convergence problem fixed but now vol.is gone
    I just posted a question about a convergence problem( juice07 ). I am unable to adjust the red color in the convergence adjustment mode. Did you have a similar problem ?? Please help.
    Sep 28, 2006 | Toshiba TP50H50 50" Rear Projection...
    Toshiba 55H70 55" Rear Projection Television Logo
    82 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
