Question about RCA F38310 38" TV
Lost Station Hello, my name is Allen, and I have an RCA F38310 that I've had for about five years. In the past week or so, I 've noticed that I can no long tune in to my local PBS affiliate station. The analog station is number 13, with the digital being 14. If I enter 13-1, the TV jumps to 13. If I enter 14, the set displays a "weak signal" message. I fired up my PC, which has a HDTV tuner card. The digital station came right up! I also have a portable tv that has a digital tuner, and it was able to tune in to the digital station too. I went through the manual, and checked everything with a fine tooth comb. I'm stumped. Can you offer any ideas or suggestions? Funny, all of the other stations come in with no problems at all, just this one station. Thank you for your time and consideration.
  • 375 Answers
Table top box from rca,to get the channels
Posted on Apr 08, 2008
Hello - I've had my SKYFi2 receiver for about 4 1/2 years. For the past 6 months it cuts in and out, as in, plays the station that I'm on, then it stops and just says "antenna". ...
Hi Kathy,
It sounds like its the antenna, although it could be the docking station itself, or even the receiver. The best way to narrow it down is by testing against other equipment (if you happen to have other docking stations and or antennas) If it produces the same result you know its the radio. If you swap antennas and it works, obviously the antenna; and the same goes for the docking station. You can find replacements at
Jun 15, 2011 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
The tv will not let me channel search keeps telling me to unlock threw service menu. tv will not work on antenna a or b and when im using the dvd threw one of the imports after five to ten minutes the tv...
Your tv is tuning locked. Go to menu and get the tuning lock function by pressing PR+,PR- keys. Reach to the tuning menu by the help of Vol+, Vol- keys. Select the tuning lock fumction, and turn it to 'off' .
Oct 14, 2010 | RCA F38310 38" TV
No picture/no sound. fan working
I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode.
May 10, 2009 | RCA F38310 38" TV
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Rca television (f38310)
using your cable box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. If you do not have a cable box you can connect your cable to the antenna A or B input jack on the back of the set and set the tv input to antenna
Mar 23, 2009 | RCA F38310 38" TV
More info on my RCA F38310 38" TV
Thanks for the reply.
Go to this site and browse through their stock of parts for this TV model. You can give them a call as well if you do not see what you are looking for.
Good Luck.
Apr 13, 2008 | RCA F38310 38" TV
Bad diode.
It seems that the number provided "CR14710" is the number near the part on the board. Are you sure this is the part number or rather, is it the part's schematic reference? I interpret "CR14710" as Control Rectifier 14710 that can be found on a schematic. I say this because you also said "a badly burned diode" and usually the part number becomes illegible from this.
Dec 11, 2007 | RCA F38310 38" TV
Rca..model f38310
My set just recently went throgh the same problem. I found a bad connection on the power board and a burned diode as well. I repaired the conneciton but have had no luck getting the specs on the burned diode. RCA has been no help.
As for cost of repair, on serviceman quoted $50 just to come take a look.
Dec 09, 2007 | RCA F38310 38" TV
Tv antenna
Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
Jul 21, 2007 | RCA F38310 38" TV
RCA F38310 38" TV Logo
127 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
