Question about IBM Office Equipment & Supplies
Help, I have a Personal Wheelwriter, need to remove the top cover and remove roller. Some Avery labels have peeled off inside and will not allow paper to advance
  • 3 Answers
BOTTOM REAR OF CASE, 2 SLOTS. GENTLY INSERT SMALL SCREWDRIVER TO RELEASE TABS.
Posted on Jun 26, 2009
Avery Labels 5366 not adhering to file folders
There may be incompatibility between the adhesive on the labels and the file folder material. You might be using plastic folders or folders coated with something that affects the adhesive. Why not check with Avery for a solution?
Apr 12, 2013 | Avery Office Equipment & Supplies
Im trying to print avery labels but my printer does not have a setting for it
Normally support for printing Avery Labels is found within the application you are using to create the labels to be printed, i.e. in Microsoft Office Word or similar publishing programs. . . .Avery provide a Wizard extension to use in Microsoft Word to help you to produce and print on their labels. . . .See http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-Wizard-for-Microsoft-Office.htm for further details and to download the Wizard. . . .Note: You need to allow Macros to execute within Microsoft Word in order to use the Avery Wizard.
Sep 22, 2011 | Epson Stylus NX400 InkJet Printer
I got a label stuck on the roller of my ibm wheelwriter 30. the only way to remove the label completely will be to remove the roller. How do I remove the roller or is there any easier way to remove my...
While I haven't seen your model of machine in many moons, the roller was generally not difficult to remove once the plastic housing was removed.
If it appears to be a bigger job than I recall, you could take 1/4 - 1/2 sheet of plain paper, saturate it (not dripping) with naphtha (lighter fluid) and feed it into the machine to cover the label. Allow some time to soak, feed the paper out and wipe the residue of adhesive with a clean lint free rag several times, wetting it if necessary with a few drops of naphtha to complete the removal.
You might feed several clean sheets of paper through before using to ensure no residue or fluid has stayed behind.
Aug 06, 2010 | IBM Wheelwriter 30 Typewriter
Want to know if this printer can print address labels (Avery peel and stick). Thanks.
Yes you can print Address but to print that you have to use MS word, to create it first
May 19, 2009 | Brother MFC 490cw Color Inkjet...
AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Dec 31, 2008 | Avery 9100 Thermal Printer
Easy peel Labels stuck to rollers cant print
On which roller are these labels stuck? On the drum roller? or at the back in the fuser.
If it is the drum you can always try with a soft cloth and some denatured alcohol.
Soak the label first with alcohol to loosen the glue, then remove the label and take a new
clean cloth to remove the glue with alcohol. Notice that the drum is light sensitive, don't expose it to bright light for too long.
If it is in the fuser you'll have a bigger problem. You'll have to remove the fuser first to access the rollers (caution, let it cool down first, fusers get really hot)
You need to remove the duplex unit (if available) or duplex cover and the 2 small side covers.
In the left and right you will notice 2 screws that tighten the fuser. Remove these screws as well as the dataconnector on the right and the fuser lamp power supply to the left.
Now you can easily slide the fuser out.
The tricky part is to open the fuser up to access both heat- and pressure-roller to clean them in the same way you should clean the drum unit. Normally you can open the top cap of the fuser loosening 2 screws don't know exactly which ones
When this is done you can reassemble the printer and all should work fine.
If you intend to open up the fuser, let me know, i'll get you the detailed information for that.
Notice:
when you use lables that are suitable for laserprinters always use the manual front feed and open the rear cover, that way the paper does not get folded, it just runs flat right through the printer.
Oct 13, 2008 | Brother HL 5170DN Laser Printer
Can I print a cd on my canon mp510 printer?
You need to download a CD cover creator software. If you also want to print your own CD label stickers (round ones for the disk) you will need also to buy CD avery templates.
Here is the software:
Download Super CD Cover Maker v2.0.0
Cd Cover Label Software Freeware
CD Cover Designer 2.5 {freeware} at Damn Printer
Free CD/DVD Covers Software Downloads
Cd covers Free Download
Easy CD and DVD Cover Creator and Label Maker.
Here instead you can buy cd labels:
Avery Labels, buy Avery office products, Avery CD Labels
Sep 06, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Making labels
there are software templates on the avery website. Maybe you can find the specific product you bought on the website and download a template that will help you print labels.
Mar 21, 2008 | Lexmark Z1300 InkJet Photo Printer
Forms stuck on roller
Not simply, Remove from mains, all covers must come off first, then it is obvious. Probably will need new fuser
2d9596b.jpg INFO
Ensure labels are laser type and paper type is set accordingly
Nov 02, 2007 | Brother HL 1440 Laser Printer
144 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
