Question about Andis Outliner II Hair Trimmer
IM HAVING PROBLEMS WITH MY TRIMMERS JAMMING OR STOPPING WHILE IM CUTTING . THE MOTOR IS STILL RUNNING BUT I HAVE TO STOP AND KEEP PUTTIN COOL LUBE ON THEM TO WORK TEMPORARYLY. WHAT IS CAUSING THIS
    Problem Solver:
  • 17 Answers
When was the last time u had them sharpen, if u have not have them for over a month or longer they need to be sharpen. the blade is dull when the hair is clogging
Posted on Nov 14, 2009
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered.
Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told.
Echo Trimmer Can Be Tricky to Start
"Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur."
Hope this has helped?
Feb 27, 2016 | Echo Garden
My Jeep cherokee fan motor run,when ignition switch is off,but does not run when engine is running.why?
the fans are there to cool the engine but once you stop the car the temperature is not being cooled by movement of air and water circulation via the water pump so the fan cuts in for a short time to stop the temperatures causing damage. when driving the air cools the motor enough to keep it a t the right temp no air movement no cooling.
Sep 19, 2014 | Cars & Trucks
Yard machines trimmer. 4 cycles
Victor you need to invest in some copper grease. This will stop it getting to hot and jamming when it expands with the heat.
Apr 26, 2014 | Yard Machines Garden
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
How do you keep the shaft from turning when working on it
If you're refering to working on the cutting head without the shaft turning then you should be able to lock the cutting head to remove it. There is a small hole in the top of the gear head that you need to put a small rod in to jam the head from turning.. this inturn will also stop the drive shaft from turning.
Sep 03, 2012 | Husqvarna 28cc Gas Line Trimmer
The treadmill runs fine until i step on it then it stalls and stops running
There is a motor which spins the treadmill belt.When you start the treadmill, the motor starts running and belt spins smoothly.But when you step on the treadmill, the motor cannot take the load and it stops working.In your case, the motor and motor control board is got weak and this is causing the problem. ---------- Or the other possibility is the treadmill belt, the belt on which you step.That belt should be smooth, there is grease in the inner side of belt to keep it lube and run fluently.If that oily grease gets dried up then belt gets bit stiff or jammed up, when a load is on belt.So get this both possibilities checked.First try lubing the belt internally and then try check the motor and motor control board.To locate motor control board its simple.On the side of motor you will see a electric plug in connector, the other end of that connector gets connected to motor control board.Remove that connector , clean it and reconnect after 5 minutes, then check.In some cases this resets the internal control system and everything, works normally.But its not always possible then removing and reconnecting connector helps.In other cases the motor or control board needs to be replaced.If the motor gets weak, then internal coils in motor gets burned up.----------- This will help.Thanks.Helpmech.
Mar 26, 2011 | Proform Exercise & Fitness
Toro electric trimmer motor keeps stopping
Very possibly a bad switch or loose wire.
May 17, 2009 | Toro& Electric Trimmer
Motor stopped running but lights & ice maker OK
this is most likely a bad condenser fan motor. pull refrig from wall remove compartment cover on rear and inspect the fan that cools the compressor. it is either jammed or seized up and needs replacing. while your at it you may want to clean the condenser coils as well they most likely have dust and lint build up on them. this motor is fairly easy to replace yourself if your mechanicaly inclined the part number should be 833697blade and can be purchased online, at a local appliance parts supply house, or thru a sears parts and servie center near you.
to keep the unit working until you get it repaired you can put a house fan blowing on the compressor area to keep it cool and this will get temps back to normal and cool down that center frame as well.
Thanks Peyton..
Feb 24, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dies at idle,fluctuating idle in neutral and park,
it sounds like your alternator is havin problems it might not be puttin out enough juice at idle to keep everything workin make sure you clean all the connections you can to
Nov 04, 2008 | 2004 Ford F150
Andis Outliner II Hair Trimmer Logo
171 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
