Question about Canon PIXMA MX310 All-In-One Printer
How do I get it to print in black???
How do I get it to print in black and leave out the color??? The start buttons that read red and black don't respond if i just want to print a document only in black.
  • acnak Jun 26, 2009
    Much thanks for your response, but I goofed I forgot to mention that I have a mac not a pc. Any advice?
    Problem Solver:
  • 15 Answers
When you are ready to print, let's say you're using Microsoft Word, go to the print menu. Before you go ahead and print, click the 'Printer Properties' tab and switch the colour tone to only black and white. Then print and you're done. Hope this helps :)
Posted on Jun 25, 2009
My color inks are out of ink but still in the printer...i just replaced the black ink. when i try to print, it will not allow me and says to replace the color inks first. i followed the instructions to...
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the color ink.
Note: Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality if you want to print color in the future.
Sep 23, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I have a laserjet 2600n - the black prints perfectly but where i have colour, especially the blue and red, they seem to shadow each other. if i have a web address, when i go to print it there will be the...
May just need a calibration.. Try this:
  1. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads System setup and then press c00314544.gif (SELECT).
  2. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Print quality and then press c00314544.gif (SELECT).
  3. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Calibrate color and then press c00314544.gif (SELECT).
  4. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Calibrate now and then press c00314544.gif (SELECT).
  5. Press the c00314544.gif (SELECT) button to confirm Calibrate now.
Jul 20, 2011 | HP Color LaserJet 2600n Printer
Lexmark x6180 Printer. Unable able to Scan. I turned on my printed and selected "Scan" button, located with two other buttons ("Copy" and "Fax" under the section titled...
On the printer operator panel, press Black to begin a black and white scan or Color to begin a color scan. You can rename the file only on your computer once the scanned file is displayed.
Jun 19, 2011 | Lexmark X6180 Printer
HP c3180 color printing problems
I would definitely start by printing a self-test page. With your model press and hold the Cancel button and then press the Start Color Copy button and then release both buttons. When this page comes out you should be able to identify the 4 different color sections...black, cyan, magenta and yellow. If any of these seperate areas are choppy or non-existant, you need to replace your cartridge. Here is a link that will show you examples of what you should/shouldn't see on the self-test report.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00661556&lc=en&dlc=en&cc=us&product=1146331&rule=25470&lang=en
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    My hp 2600n color laserjet leaves RED DOTS on the printed document. What should I Do?
    look at the red cartridge do you see any dots on it ? is it only when you print? what about if it's just Blk & wht?
    Jul 21, 2008 | Sharp AR-5320 Black and White Copier
    Epson stylus c45
    epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
    Jul 17, 2008 | Epson Stylus C46 InkJet Printer
    No color prints
    When you tried to print, did you press the button for black or color? Either one of these will be the start button. If you hit color and it still prints in B&W, the other solution is to the pop-up box should come up then you click on advance options. file-print --then click on preferences just below your icon list of printers. Two pop-up boxes will appear. close the smaller one (I want to...), and the other box should stay open. You will see on the lower right corner the box to check off for "print color images in black & white. Make sure the box is unchecked. then click ok, and print.
    Dec 11, 2007 | Lexmark X6170 All-In-One InkJet Printer
    Canon PIXMA MX310 All-In-One Printer Logo
    382 people viewed this question
    old marine
    old marine
