Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Color change Extreme color change --all greens and blues--no reds at all and all colors are affected--like white appears a blue/lavender color. I've tried to adjust the color through all the menu options with NO effect. I wonder if this thing is shot? It is 3-4 years old. Thanks
  • Camzilla Dec 05, 2007
    I am having the same issue. Blues, greens are good, but reds are gone. I played with the manual adjustment, however, no solution found there. Whats the solution? Is it a bulb issue? Do these things have bulbs?
I had my stk's replaced, was able to take out the board and brought it to a tv repair shop, the fellow replaced the circuits and re soldered the circuits and heat sinks. Circuit Barn- Auburn, Mass. Jeff Murray did a great job. Reinstalled, and 56 point convergence, tv looks as good as new. I was disappointed too, because the set was purchased in december of 2002.
Posted on Dec 30, 2007
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
Cat 5 cable
The normal color code is. Orange white, orange, green white, blue, blue white, green, gray white, gray. the wire using for network only 2 pair. That is 1,2,3,6. For normal telephone - use blue pair (4,5). For pabx system use. 3,4,5,6. Connection. You can use any Color code If both ends are same.
Jul 02, 2012 | Computers & Internet
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Need color code for radio harness
Hello Mexicano1037,
Here are the colors for the radio harness on your '91 Escort.
1991 Ford Escort Radio Color Codes
Battery Constant 12v+ Wire: Blue/Red
Accessory Switched 12v+ Wire: Blue/Black
Ground Wire: Black
Illumination Wire: Red/Black
Left Front Speaker (+): Violet
Left Front Speaker (-): Blue/Orange
Right Front Speaker(+): Blue/White
Right Front Speaker(-): White
Left Rear Speaker (+): White/Blue
Left Rear Speaker (-): Red/Blue
Right Rear Speaker (+): White/Green
Right Rear Speaker (-): Blue
Hope this helps.
Apr 12, 2009 | Car Audio & Video
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Change the colour
CLICK HERE for a PDF copy of your owner's manual.
Page 17 States to change the display color -
Setting the Multicolor Illumination
ILLUMI BLUE (Initial setting) / ILLUMI GREEN/ILLUMI AMBER /
ILLUMI RED
You can change the lighting color of the following four buttons:
SOURCE/POWER, BAND, (left << arrows) and (right >> arrows).
BLUE > GREEN > AMBER > RED > BLUE
• According to the lighting color of the above four buttons, the color
of the other buttons also changes. When the color of the four
buttons is AMBER/RED, the color of the others is AMBER. When
the color of the four buttons is BLUE/GREEN, the others are also
GREEN.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | Alpine CDA-9847 CD Player
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
