Question about Sylvania SY-550 14 in. TV/VCR Combo
Horizontal sync problem. replaced IC301(LA7685J), ceramic resonator(X303) and all electrolytic caps around horiz circuit.
  • 1 more comment
  • actelec Jun 25, 2009
    no solutions so far
    Sylvania security monitor SY550 TV/VCR. No horiz sync. Changed LA7685J IC, ceramic resonator and all electrolytic caps around horiz circuits.
    what is your answer to my problem?
  • 555 Answers
My friend the only solution you have their is to replace the damage IC, ceramic resonator and all electrolytic caps around horizontal circuit cause that's the only way you problem may solve. Since the IC is damage the only solution it can get is to replace the damage one and replace it with new one. You can find or buy IC and other parts in the shop specializing the same brand as you have. Also find a service shop in your place or a technician to help you fix your problem. So my recommendation is replace the damage part of the circuit. you can either fix it your self if you know how or you find someone or service shop to fix it for you.
Hope this solution helps your problem solved. If you need more assistance just reply to this post as soon as possible and i am eager and willing to provide you some assistance. Thank you and godbless
Posted on Jun 26, 2009
    Sergeant:
  • 326 Answers
En.allexperts.com/q/TV-VCR-Stereo.../13-inch-sylvania-tv.htm
Posted on Jun 25, 2009
    Sergeant:
  • 296 Answers
Retarce line
Diagonal retrace lines at the top are usually the result of bad electrolytic capacitors in the vertical deflection circuit most vert. deflection circuits derive operating B+ from a horizontal flyback transformer winding rectified & filtered usually around 24 volts the electrolytic capacitor on this supply loses capacity or may totally go open causing the retrace lines,sometimes other electro. caps in the vert circuit can cause this too, depending on the age of the tv you may find multiple substandard electrolytic caps it's best to test all for capacity & esr. Without knowing more details about your tv brand,model and/or chassis i can't help further.
Apr 14, 2014 | Sansui Televison & Video
Can i use 10nf3k ceramic capacitor to replace10pf3k ?
Hi Max,
Ceramic types are often found at the low range of capacitive values and electrolytic types are are the high end of capacitive values. Ceramic and electrolytic caps do certain jobs better when of one design instead of the other. The capacitive values may be the same, but there are other qualities that don't get printed on the part. One of the most noticeable differences is that electrolytic types don't do a very good job passing radio frequencies (RF). You'll often see several ceramic types in parallel (if needed) to get the correct amount of capacitance when a single electrolytic would appear to do the job in an circuit where the frequency is in the RF range. Audio Frequencies (AF) on the other hand are significantly lower and do not pose the same problem. There are other types of caps and they each have situations where they would do the best job.
In short, the developer / manufacturer selects all the parts based on a wide range of variables he needs to control based on design and testing. You should always replace components with like components, otherwise you risk adverse reaction(s) from one of those variables that had originally been contained.
Click the link below for some basic info about caps:
http://dev.emcelettronica.com/guide-to-capacitors-electrolytic-capacitor-ceramic-capacitor-and-others
I hope this was helpful & good luck!
Nov 05, 2012 | Computers & Internet
Audio and picture go dead red light blinks 7 times
A protection circuit has cut in - possibly due to a fault in the line output stage (flyback transformer could be short-circuit and horizontal output transistor could also be shorted).
Assuming the power supply/HT rail is all OK, replace the above parts, touch up any suspect solder joints, check and replace any capacitors (electrolytic and the tuning caps in the collector of the horizontal transistor - always replace these caps (rated at around 2kV - 6kV) whenever you replace the flyback)
Jan 24, 2011 | Sony FD Trinitron KD-36XS955 36" TV
I have two Sony KV-27FS120, they have the same problem, 4 blink, both have no vertical & horizontal drive from IC001 jungle chip, and Q505 horiz output blow. Circuits between them look good. I replace...
Check very carefully for cold solders on horiz. drive transformer also replace the electrolytic cap that shapes the horiz. drive signal - if you have a scope and manual compare the drive signal shape.
Some times using poor after market horiz o/p's also causes the problem - does the o/p heatsink get to hot to touch or does the horiz o/p blow immeadiatly?
Oct 19, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Pictures shrinks.. Panasonic TC-20LM Television
Shrinking picture is a voltage regulation problem in the switch mode power supply, Possibly a cap used in the feedback circuit. Or an over current condition on the B+. This is a very tech intense repair because there is no magic bullet. If it is shrinking on bright scenes then you can bet it is a regulation problem, bright scenes draw more current from the power supply causing this effect. I would not suspect the horiz output because the regulation for this circuit usually comes from the main switch mode power supply. One diagnostic is to monitor the B+ going to the horizontal output and see if it fluctuates. If so you can bet it is a cap or optical coupler in the switch mode circuit.
Oct 10, 2009 | Panasonic Televison & Video
Picture goes into horizontal lines while watching then you shut it off for 10 min. or so and it resets it self
solder connections in horiz.drive/output circuit.also solder the flyback transformer.if only 10 minutes you need to solder in the
horiz.circuit area.get a magnify glass and usually will see hair line cracks around the
components.
Jul 17, 2009 | RCA TruFlat 27F520T 27" TV
Come on then line horizal across screen then turs off
Horizontal line (up and down) is know as horizontal collapse. This is usually located around highvoltage section of the circuit. Because this circuit depends on certian frequencies and voltage protection circuitry will shut the set down. This will need a trained tv technician to fix this and can be expensive depending on the parts needed.
Mar 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Tv lack of horiz. width
hi there, lack of horiz. width means horizontal section problem, test some electrolytic capacitor at horizontal section and try video section. ty
Jan 27, 2008 | Televison & Video
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
Horiz sync
take the tv to a tech the tv is haqving a problem in the power and the horizontal circuit.you can get a schematic from www.samsphotofact.com
Apr 03, 2007 | Samsung TSK2792F 27" TV
Sylvania SY-550 14 in. TV/VCR Combo Logo
73 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
