Question about HP Photosmart C6180 All-In-One InkJet Printer
Carriage jam error message. How do I clear it?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
SOURCE: Carriage Jam error always - how do I fix it?
Try resetting the printer (pressing the cancel button and connecting the power supply, check in the HP website if this is correct for your printer model) , after the reset the printer will clear any errors and will recalibrate the mechanism including the paper feed mechanism and the carriage.
Also check if the carriage is moving freely by disconnecting the power and moving it by hand.
Posted on Feb 04, 2008
SOURCE: error - carriage jam message
My Photosmart 2610 just started having this same problem today. As many of you have done, I also went to the hp support website and tried just about everything. Finally I discovered the answer to my problem on my own. Here's what I did (you might want to have a wet rag handy to wipe the ink off your fingers):
1) With the printer on, I pressed "okay" to clear the error message. You should immediately hear the sound of the carriage (the contraption that holds the cartridges) moving inside.
2) Open the print cartridge access door (the main access point for the cartridges) and confirm that the carriage is indeed moving.
If the carriage won't move at all, I'm not sure that this solution will help you. However, if the carriage moves from side to side after you press "okay", please read on.
3) This is unorthodox, so bear with me: when the carriage moves away from it's "resting place" (in my printer it's on the right hand side) and is near the center of the printer, unplug the power cord from the printer. The purpose of this is to free up the undercarriage (which was the part that actually was jammed on my printer).
4) Ensure that the carriage moves freely from left to right and right to left by pushing gently on its sides.
5) Move the carriage to left side of the printer so you have room to access the undercarriage.
6) It might be helpful to have a flashlight or some other light targeting the undercarriage for this next part. If you look directly underneath the undercarriage, you should see a foam/spongy product resting in the base of the printer. The purpose of the sponge is to absorb any ink that escapes from the cartridges. Herein lies the problem: over time, as the undercarriage adjusts to enable the carriage and its cartridges to do their work, the undercarriage gets caught on the inky sponge. Note that the undercarriage is fragile, but is moveable by gently pushing it toward the front or back of the printer.
7) Adjust the undercarriage so you can see the sponge and the "axel" (for lack of a better term) that turns to move the undercarriage forward and back. It may take some detective work, but you should be able to determine where the sponge is supposed to lie. Your goal here is to push the sponge down as far as it will go so that it won't obstruct the movements of the undercarriage.
8) On my printer, there was also a small amount of sponge wrapped around the "axel" that prevented it from moving smoothly. I unwrapped it and double-checked that nothing else was obstructing movement.
9) Final step: leave everything where you moved it, shut the lid, and plug it back in. A little prayer never hurts either. Good luck! AIM ID if you need more help: GnarlyVeaux
Posted on Mar 10, 2008
hashir4u
  • 79 Answers
SOURCE: carriage jam message
unplug the power cable without powering the printer off,
press and hold # & 6 on the printer ... while holding these two keys connect the power cord and do not release the keys till the screen turns off. press the power button to turn the printer on ... it ll go through a reset and it ll be working fine, if the issue persists let me know
thanx
Posted on May 23, 2008
Khalsa007
  • 79 Answers
SOURCE: Carriage jam error
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7 Allow the all-in-one to re-initialize. This may take a minute or two.
8 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Thanks
Posted on Jun 04, 2008
SOURCE: HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Posted on Jan 01, 2009
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
I have an HP J 5870 All-in-One printer; Error message says, "Carriage jam". There is no obvious jam, carriage moves freely and I cleaned up the ink puddle under the black cartridge. Can't clear the error...
If the carriage moves on it's own, then the message comes on, you may need to look for the carriage home possition sensor and clean it. the sensor will be located at one end of the carriage travel. THe carriage will likley have a tab that will pass through a slot in the sensor. the best way to clean this kind of sensor is to use canned air. good luck.
Oct 06, 2010 | HP Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Clear carriage jams
use some lubricant or oil (minimum) for cartridge rail
Feb 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
164 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
