Question about Nintendo DS Console
Bottom Screen I dropped my Ds and now there is a ripple in the screen that puts pressure on the left side I can pry it up with my finger nail by the frame and it works for a while but then pops back. Therefore I think I should replce the bottom screen but can't seem to find detailed instructions on the alone. ThanksMuriel
  • madMur Nov 06, 2007
    do you think I need the whole bottom screen replaced? I understand there are 2 parts to it,
  • 155 Answers
Try to get hold of a tri pronged screwdriver to open up the back of your ds (you can get them from "". Once you have opened it it should be easy to sort out as you can take the whole screen apart. It's quite easy once you've got the screwdriver :-)
Posted on Nov 06, 2007
The touch screen doesn't work with my finger tip, only when my nail touchs screen, also did the screen calibration, did not not help
It may be a resistive screen rather than a capacitive screen which is not as sesitive to touch. You may need to use a stylus as it may need slight pressure vs just touch if it is a resistive screen.
Apr 05, 2013 | Garmin zumo 550 GPS Receiver
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
How to flip screen around
The 6th generation iPod nano doesn't have an accelerometer, but its screen can still be rotated. Here's how.
Begin by putting two fingers at corners of the screen. This can be opposite corners (one finger at the top right corner of the screen and another finger at the bottom left corner, or vice verse) or corners on the same side (top left and bottom left, for instance).
At the same time, twist your fingers in the same direction (clockwise or counter clockwise). The screen should rotate with your fingers. Remove your fingers from the screen when it's oriented the way you want.
If you like my solutions kindly rate it.
Thank you
May 20, 2011 | Apple iPod Nano 6th Generation MP3 Player
Touch screen is not working properly
the reset on a 255w is NOT under the frame around the screen. it is located under the sticker on the bottom of the 255 where your serial number is.
Standing Member of G.O.T.
Oct 03, 2010 | Garmin nuvi 255W GPS Receiver
HP DV9000 My laptop screen is loose i would
When the laptop is flipped over, remove the battery. Under the battery there are 6 screws placed in pairs, these have to be removed. Once these are removed, the speaker and power strip can be pryed up, start with your finger nails on the right side and pop it off. Be careful with the flat cable in the middle of the strip. Tighten the screws for the display there and I think there are some that tighten from the bottom. Also, remove the rubber pads from the screen bezel and remove the screws from the screen bezel, then pry the bezel off at a corner and work your way around the bezel until it is removed. It will somply snap back on when you are finished. Tighten all the screws you see that connect to the hinges, this is wher the screen loosens alot. Just pay attention to the wires that feed through the bezel from the screen to the motherboard. Take your time, nothing to it.
Aug 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Spider web behind front of screen
Take the front speaker grill, and ther will be a few screws on the bottom of the screen. Remove those and lift the screen up and out.
Feb 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
I need to take the back off a navman s70
Im surprised noone has answered this considering navmans track record for producing waste products. I say this,as i have 5 sat useless,due to being 2nd owner,so uncovered by warranty,in some cases,units being less than 1yr old,so i have had a look myself. Ok. Here goes. hold the unit screen towards sky,base facing you. You will see 2 screws,one either side. These hold the side covers in position. Remove these,and if you have strong nails,insert finger nail between side cover and back,start at bottom and pop the bottom lug then the top. It should be held the same on other side of side cover. repeat this on other side of unit. The side covers should now be off and exposing back cover side edges now. Take your finger nail and insert between back cover and base at one corner,it should pop open slightly,repeat on opposite corner. This is from memory. your cover should now lift off. Try the screen ribbon where it joins the board for connection first,there is a tiny black lift up ribbon lock to lift up then make sure ribbon is pushed firmly home,maybe even clean the connectors. The rest is in your hands if this does not work. Good luck.
Jan 21, 2009 | Car Audio & Video
Nintendo ds lite screens dull
in the bottom left hand corner of the ds screen, there is a icon that looks like the sun. touch it and it will light up.
May 07, 2008 | Nintendo DS Lite Console
Hoth battle complete saga ds
finally done it!!!. When the cable attaches to the AT-AT it should drop the screen down to the bottom screen then take your stilus or use your finger and draw circles in the direction the ship is going around the AT-AT. good luck
Jan 12, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
