Question about Whirlpool GHW9150 Duet Washer
Whirlpool duet washe always out of balance
I own a whirlpool duet washer and it has started vibrating on every spin cycle like it is out of balance. Had no problems with this at first but now is jumps around on every load - what can be done to balance the machine?
  • 126 Answers
Remove lower front panel and you should see shocks on lh/rh of tub. probably one broken ,replace both. Hope this helps, please rate my solution :)
Posted on Jun 25, 2009
My whirlpool Duet 9750 takes a long time to spin out and has a difficult time trying to balance
I owned a Whirlpool Duet and had spin/balance problems when I washed heavy and light items together. During a deep freeze my drain hose froze. Did everything I could think of until I ran hot water through washer. It took awhile to thaw. If your floor is weak, you will have a lot of vibration and walking. Hope this helps.
Dec 28, 2011 | Whirlpool LSW9750 Front Load Washer
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
Washer balancing load, during spin cycle wasker shakes and walks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
Washer Problems
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wfw9550 keeps getting out of balance on spin cycle i have re-leveled the washer 4 times now and it keeps going crazy on spin cycle how do i fix
Their is a auto balance circuit in the machine. it a sensor, it will adapt the machine... you may have a failure in this machine....
Dec 19, 2010 | Whirlpool Duet WFW9550 Washer
Whirlpool duet washer went out of balance during the spin cycle
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle of my duet washe3r is very loud
are you sure your machine is balanced and installed on a sturdy foundation?
May 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle
the machine has sensors within it that detect off balance loads, very possible that the 1 or 2 items are not enough to correctly balance themselves, so the machine will never achieve full speed spin.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
640 people viewed this question
Dan Webster
Dan Webster
Sal De
