Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I am putting a new belt on my deck, model 917.258540, i see how the braker for the mower pully will tighten when i engage the clutch, but after i disengage there is nothing pulling the bar back into a positionclose to the pully so the belt wont fly off, is this how it is supposed to be configured? also, any tips on putting the deck back on by myself...other than getting a friend to help? thanks Tom ps this is a 15.5 HP kohler engine
  • 513 Answers
The brakers on the pulleys should go against the pulley when disengaged & if you do one side at a time you can put deck back under yourself if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
How to tighten yard machine riding mower deck belt
indicates incorrect "V" belt used as replacement
The belt should be just proud of the edge of the pullies
If there are steps in the grooves of the pulleys they they need replacing
the adjustment is by a spring loaded idler pulley
Apr 28, 2018 | Garden
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My blades will not engage. Just stopped while mowing. Model 917.273130. Seat operator present switch seems ok. Belt and pullies look ok. Blades not obstructed. Tractor starts and runs ok.
Check for a broken belt, then the cable and linkages and the pulleys on the deck. Sometimes the two smaller pulleys on the deck break. It should be evident when you put your hand on it and try to turn it.
Aug 17, 2011 | Craftsman Garden
Need to replace Deck Belt on aa Model 3225 Club Cadet . Need a diagram of how the new one goes on.
this may help Tim:
http://www.ehow.com/how_6182447_remove-mower-deck-cub-cadet.html
May 26, 2011 | Garden
I have a murry 42" riding lawn mower and i just put a new deck belt and when i engage it works fine but when i disengage it the belt comes off i dont know how to fix it
This sounds like either a worn bearing, or a bent bearing carrier on the mower deck shaft. The belt is thrown off by a misalignment of the deck pully, when the belt is loosened by disengaging the mower.
Aug 12, 2010 | Garden
Lever won't engage blades
check to see if a belt came off, it would go from bottom engine pully to deck lever pully then around blade pullys on deck. the pully under neth has to tighten belt to run blades the pully is ether solid to lever or has a cable that moves it make sure cable did not break hope this helps
Jul 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 18.5 riding mower when I engage the blades to cut the blades turn But they do not engage NO Power.Blades Turn But Not enough to cutthe grass.
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ariens sierra 1440G belt configuration
Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
If this doesn’t work for you, please write back. Thanks,
Nov 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
101 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
