Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I am doing the auto channel search and it can only find 12 channels
    Problem Solver:
  • 16 Answers
Make sure you are in cable mode for auto program
Posted on Jun 26, 2009
Auto Channel Search, how do you accomplish this.
Use your Insignia remote to select the initial set up procedure and run auto channel search.
Mar 03, 2015 | Insignia Solutions NS-24E200NA14 24" LED...
Channel 12 will not scan. it is not listed in favorites and I cannot ,enter it in favorites
Try and run an auto program on your television through the settings to scan for Channel 12. Sometimes the channel can get deleted and just needs to be searched again to work.
Apr 06, 2014 | Televison & Video
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
I need the code to do an auto channel search for my lg tv so i can go up and down from channel to channel instead of typing the number to the channel in
Your auto channel search should be in your menu on the TV. Find your menu button on the front of your TV or on the remote.Make sure before you do a auto search you set your TV to cable, that can also be be done through your menu screen. If you can change the channels on the remote and control the volume your remote is already programmed.
Jul 15, 2009 | Quasar SP-2725 27" TV
Local channels gone?
You need to go to set up menu & select the cable & start
Feb 01, 2009 | Televison & Video
Auto Channel Search
sounds like the tuner section of the main pcb isn't working properly.
Jul 28, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Cant use all cable channels
Go to SET UP TV, press yes for the following question. SET UP GUIDE PLUS. This will take you to another GUIDE PLUS SET UP SCREEN. Answer the questions as they appear. The important question is going to be. DO YOU HAVE CABLE? Answer yes to this questions. Answer the rest of the questions as they appear. Then go back to MAIN MENU, select channel, then select auto channel search. This will find all channels that are offered by your cable package.
Jun 08, 2008 | Proscan PS32500 32" TV
More channels
Go into the menu to the "Search" tab, channel down until you are on "auto search" then press "volume up"
this will automatically add channels you can get, you can manually change skip settings there too if you want to not see a channel you get or for some reason add a channel you don't get etc.
Mar 01, 2008 | Insignia IS 20" TV040919 TV
Tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Jan 10, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
