Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
It's been about 5 years with our Alira style kitchen faucet. All of a sudden the base wouldn't turn very well. Had handyman come in and he said the insides swell after a while, and you just can't turn the base anymore. He knows of no fix for this. Is this the problem? Any rebuild kit?
    President:
  • 2,976 Answers
Rebuild kits are available but just remove the spout, clean the inside with scotch brite and put a THIN coat of food grade silicon grease or vaseline on the 'O' rings.
Posted on Jul 24, 2009
Grohe alira loose on granite counter
Needs to be tightened from under the sink, may need a right angle faucet wrench, they are about $10, or you can try and snug it up by hand, hope this helps?
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Stream suddenly switches to spray function without pushing the button
Have you checked to make sure the switch is fully in one position or another? It maybe be closer to the middle of switch?? It could be old and worn out?
May 19, 2014 | Grohe 32 999 KD0 Alira Pull-Out Spray...
The base of the faucet which fastens to the top of the granite is loose and moves around. Is there a nut under the faucet that tightens to keep it firm to the granite? How do I fix this?
yes there is, with a pair of slip joints you can tighten from underneath, it is above the supply line, the best thing to do is turn off the water, disconnect the supply line and tighten the nut, then reconnect the supply line and turn back on the water. Good Luck Tim
Oct 31, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Water pressure very low
Sounds like the cartridge needs to be cleaned or replaced. May be clogged or faulty. This requires turning off water under the sink and pretty much taking the faucet apart.
May 03, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
429 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
