Question about Toro Lawn Mower With Toro Power Tools
Toro recycler 20071 lawnmower: purchased new traction cable, installed it, but it is too loose,..there is no place to adjust other than the clamp, but it does not tighten the cable itself, just the outer jacket. Help?
  • kristinkling Jun 25, 2009
    The cable itself ( with the black covering is a good length), but the wire cable inside it seems too long...it is connected in the front of the mower by the large spring at the end of the cable and the other end has the little metal piece that hooks into the tension/traction bar. I must have something hooked up incorrectly, but the Toro website is of no help, just shows pics of the parts, not the actual hookup. Any ideas?
    The cable is through the slot on that black piece on the handle( the adjustment part), hooked at the top and with the spring at the bottom, but the inner silver wire is so long ( with the fixed round piece that is inside the spring), that it keeps knocking the spring out of the attachment hole, and I still don't have any tension when I try to use the traction bar.
2 Suggested Answers
  • 24 Answers
SOURCE: cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Posted on Feb 05, 2009
How to repair a clutch cable on a toro recycler mower
Did the cable break? Or did it just stop working? In general you have to figure if it came off, break or did the adjustment slip. Readjust if necessary or replace the hole cable or re install it correctly. Simple Question, so many answers. And if all else fails, take it to a lawn mower repair shop.
Aug 21, 2014 | Toro Lawn Mower With Toro Power Tools
How is the traction cable adjusted on Toro Model 20027, Serial # 20005663. I'm replacing the cable and the new one is slightly different from the old one, but the Toro shop tells me it's the proper...
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
Sep 27, 2017 | Toro Power Lawn Mower
I have ordered and received a new traction cable for my Toro Recycler Lawn Mower. However, no instructions. How do I attach this cable so that the mower is once again self propelled?
That can be a tough one the cable that houses the throat cable is the secret to make it work. Look at your old cable and make sure it is in stalled in the same position and work backwards until it works . If the cable is not adjusted right you can not get full power.
Apr 21, 2014 | Garden
Traction Belt (new) continues to slip off of drive plate.
Sounds like you may need to replace the pulley as well. It has likely worn out of specification.
I recommend that you contact your nearest authorized service center, or contact Toro directly for assistance.
I trust this information proves useful.
Oct 02, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
May 19, 2009 | Garden
Cable traction needs adjusted
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
799 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
