The solution just given did not help as it is the very bottom plate under the bobbin casing that is out of time with the needle.
SOURCE: Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
SOURCE: Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
SOURCE: My needle was hitting the
The most common reason for this is that the bobbin case is inserted the wrong way. There's a slot on the bobbin case. When it's inserted into the machine this should face up. The needle comes down through this slot and picks up the thread from the bobbin. If it's put in the wrong way the needle hits against the case and cannot get through to the thread on the bobbin.
The other possibility is that the new needle doesn't fit properly. It may not be pushed fully up into the machine. Sometimes this can happen if the needle is too thick for the machine or if the screw wasn't loosened enough to allow the needle up fully.
SOURCE: I have a 5050c singer The bobbin case jump out
I think that you have had the wrong size bobbin. It should be a class 66. Look in your manual, it should tell you. If, that is not it, call Singer at 1-800-4singer and ask if it sounds like the timing and if so where can you take it to get fixed. This is a nice machine, my friend, has one and it is worth getting fixed if you like it.
Testimonial: "it was in the timing .problem solved. thank you for your help. "
