Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
Error code F1 displayed on unit
Amcoraire model #s:
Outdoor Model: aos121hx
Indoor Model: aws121hx
The unit isn't blowing any air out. I've tried resetting the circuit breaker that controls the unit. If I reset the breaker when the unit is in Fan mode, it comes on for about a minute and then turns off with the error code. If I reset the breaker when the unit is in Cool mode, it doesn't come on at all.
I have my installation and owner's manuals, and neither of them give any detailed information about error codes. My AC contractor has no idea how to fix it. He's checked the wiring and says it seems fine.
I contacted the company tech support via the website at amcorgroupusa.com. It would be nice if the website gave actual info about things like error codes on their tech support pages, but all they give is a contact email/phone #. When I call them, I only get voicemail and they have yet to call me back.
I also emailed them. It took them 2 days to reply to my email, and all they said is that the error codes are model # specific and I hadn't given them the model #. So I have emailed them again with the model #. I am still in the midst of what I assume will be another 2-day wait for the next email reply.
Does anyone out there know what these error codes mean? Beyond this problem, I'm really concerned about what this means long-term. Since they don't seem to publish the error codes in general and you have to email them to find out what each one means, what if the company goes out of business? All the units they have sold will be totally unmaintainable.
We had the exact problem with our unit at work. What we did was turned the unit off at the panel and grounded L1A (or B depending on which fan is displaying the error code) at the condenser and then verified that L1 was grounded at the air handler. In our case it was not, so we rolled L1A and L2S at the condenser. This fixed the error code on our units. Evidently the units need the same sequencing on the fans that the condenser has.
Posted on Jul 24, 2009
  • jeremymj78 Jul 24, 2009
    I hope this helps your problem
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Flashing F1 display on status window. Unit will not start. It will chirp in response to remote control,but takes no action.
What model do you have, the UCHW model is a 13 SEER and only displays error codes starting with the letter ' E '
Email: Support@Pridiom.com
Nov 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
E7 error message
The E-7 error code means the 2 wire defrost cable between the outdoor & indoor unit is disconnected or broken
Sep 10, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I have an F1 error code. The manual states that this means the inside and outside units are not communicating. What should I look for
F-1-No communicationbetween indoor and outdoor. Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Sep 09, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hello unit has been running then just stop with F1 showing how can i fix this thanks cameron
The F - 1 error code shows a failure of the PFC & IPM circuit boards inside the outdoor unit.
We stock a complete line of Amcor parts.
Support@Pridiom.com
201-266-8234 option 2
Aug 03, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Hi I have an Amcoraire aos121hx mini split, it worked great last summer and this past winter. Haven't used it for a few months and now when I try to get cold or heat it gives a P8 error?
Check the gas pressure by depressing the Schroeder valve under the cap where the gas pipes enter the outdoor unit. you have probably lost some or all of your gas
Apr 21, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
I have a minisplit unit that leaks out the freon
try leak stop that they sell for refrigeration and air conditioning systems
Dec 12, 2009 | Heating & Cooling
Air conditioner shuts off
C5
Communication Error
• Wrong or missing wiring between indoor and outdoor unit cable
• Defect of communication components in indoor pcb assembly
• Defect of communication components in outdoor pcb assembly
• Defect of power supply components in outdoor pcb assembly
• No ground connection in air conditioner unit
(affected by noise in power source)
Jun 30, 2009 | LG Heating & Cooling
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
915 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
