HAIER AIR CONDITIONER
I SEE MIST OR STEAM COMMING OUT OF THE TOP. WHAT DOES THIS MEAN . IVE HAD IT FOR A YEAR AND I WANT TO MAKE SURE IT WONT HURT US
    Problem Solver:
  • 17 Answers
It should just be the water in the air condensing.The same effect causes fog.Its only water vapor,and is completely harmless.The air passing through your air conditioner has water in it in the form of a gas.As this gaseous form of water is cooled it changes back into the liquid state.(In this case in the form of a fog,or fine mist)This is what you see blowing from the cold air return of your air conditioner.
Posted on Jun 26, 2009
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
There is what appears to be "steam" blowing from my airconditioner into my room. What should I do?
Due to high humidity and perhaps, an air intake filter that needs to be removed and cleaned. That "steam" is actually a misty fog and is harmless. Window & Thru the Wall AC units often do this when the outside humidity and temperatures are high. Keeping the air intake filter clean will help to lessen this mist.
Hope this helped to allay your concern. Thanks fo choosing FixYa.
Aug 04, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
I just had this unit installed. Purchased it last year and don't have receipt. Mist blowing out the back and leaking coolent? Can it be repaired since I can't return it to store?
The mist you're seeing is probably a result of high humidity in your area, affecting the cooling coils and the cooling fins. I doubt that it's refrigerant gas. But, if you notice a significant change in the cooling capacity of the unit, you may want to have it checked.
Jun 28, 2011 | Haier hwr10xc6 Air Conditioner
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
Water leaks out all over the floor from the window air conditioner
you need to make sure of two things.
1) the AC is 'tilted backwards' just a little bit - to allow the water (condensate water from the evap coil) to drip from the bottom of the AC - out the 'condensate drain hole' - sometimes into a drain hose (usually rubber) or just through the hole to somewhere outside where it doesn't hurt anything.
2) make sure the - condensate drain hole, and drain hose - (if one is used) is clear and not clogged up - to allow the condensate water to drain.
hope this helps
Jun 26, 2010 | Haier hwr10xc6 Air Conditioner
Do I add salt with the water when using this cool mist humidifier
Hello
Ive been down this road before,sorry your son is sick.
Take a teaspoon of salt and add it to a full tank,it will break up the corrosion on the heating elements,a teasspoon of baking soda will help also.
This will not hurt anyone if it blows into the air with the steam.
May 12, 2010 | Vicks Healthmist 4100 Humidifier
Just got car fully serviced while driving a short time ago heard a loud bang .stopped the car and noticed steam comming from bonnet couldn.t see anything wrong
No coolant sprayed anyware?
it could be an air conditioner hose popped. Does your air condioner still get cold?
You should see traces of oil sprayed near the problem.
Nov 11, 2009 | 2000 Daewoo Lanos
Haier wall-unit AC wont work
Try unplugging the machine, waiting a couple minutes, then holding down the power button as you plug it back in. Hopefully you will hear a "beep". Then unplug it again, wait a couple minutes, and plug it back in. This procedure works for clearing the "E1" code from some of the Sharp models, so maybe you will get lucky and the same manufacturer made the control board in your machine! Couldn't hurt to try it out. ;)
Jul 31, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
