How do you set and connect psp to wireless internet. thank you
Getting online with your PSP is very simple. First, you must be in
range of a Wifi hotspot (wireless local area network). You can adjust
network setting to connect to an access point such as a Wi-Fi hotspot
or the router on a wireless home network and save the network
connections data on your PSP®. Up to 10 connections can be saved.
Once in range of the hotspot, go to "Settings"
menu, >> "Network" Settings and press "X" Button. Select
"Infrastructure Mode" or "Ad Hoc Mode" and press X Button. Set up the
"New Connection". For details about Infrastructure Mode set up, or Ad
Hoc Mode set up, visit us.playstation.com. hope this helps.
Power on
your Wii console and press the A Button on the Wii Remote to reach the Wii main
menu. Use the Wii Remote to select the psp" button. Now,
select "psp Settings" to access the "System Settings"
menu. Using the arrow on the right side of the screen, scroll to page
two and select "Internet." Select
"Connection 1: None"(Don't see "None" in Connection 1?
Click the Connection 1 button, then choose "Clear Settings.") Click on
"Wireless Connection" and then "Search for an Access
Point." Select
"OK" and the Wii will display all the wireless networks it finds. Select
the wireless network that is yours Select
"OK," "Save Settings," and then "Yes."The psp console will run a connection test with your wireless network when the test is completed. You should see the following screen.Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the psp will begin to download any available updates.
